Trigger with variable value and last 5 minutes
  • johannesraff
    • Nov 2017
    HI,
    I am working on a monitor for VPN Tunnels. The values range from -1, 0 , 1 and 4
    The different tunnels per system are learned by a dynamic Object, but I have issues with the triggers.
    I want to learn the current state of the tunnel and then have a trigger that launches if the value changes, but not immediately but only after a grace period of 5 minutes (I am checking every minute) or after 5 values.
    I have tried different trigger methods, but I was only able to have the trigger launch, when the issue happens the first time and not after 5 minutes.
    The reason to do that is to avoid flapping of the monitors.
    I would appreciate your feedback a lot
    Johannes
