Minor Upgrade 3.4.1 > 3.4.4.2
  • sejuras
    • Feb 2017
    Any guidance on completing a minor upgrade from 3.4.x to 3.4.x.x - specifically is it necessary to recompile & 'make install', then copy all web frontend files from ../zabbix/frontend/php/*
    /SJ
  • kaspars.mednis
    • Oct 2017
    • 349
    What is your OS ?
    Have you installed zabbix from sources or packages ?
    If you have installed from sources, you will need to recompile zabbix-server, and copy all zabbix web files
    Regards,
    Kaspars
