Actions fail to email users on certain triggers
  • pmsilva
    • Sep 2017
    • 12
    Hello everyone. I really hope I can explain this properly in order to get some help.
    Here is the situation. I have setup actions based on triggers to email out when there is a problem, however certain actions will email out to the users but others will not.
    Here are the triggers in the ACTION:
    Maintenance status not in maintenance
    Trigger = BMSQL-HOST-QA01: Free disk space is less than 5% on volume C:
    Trigger = BMHYP-HOST-QA01: Processor load is too high on BMHYP-HOST-QA01
    Trigger = BMHYP-HOST-QA01: Lack of free memory on server BMHYP-HOST-QA01
    Trigger = BMHYP-HOST-QA01: Free disk space is less than 5% on volume C:
    Trigger = BMHYP-HOST-QA01: Free disk space is less than 5% on volume E:
    Trigger = BMSQL-HOST-QA01: Free disk space is less than 5% on volume E:
    Trigger = BMSQL-HOST-QA01: Free disk space is less than 5% on volume F:
    Trigger = QA-HOST-DEV01: Drive Space on F LOW QA-HOST-DEV01
    Trigger = QA-HOST-DEV01: Drive Space on G LOW QA-HOST-DEV01
    Trigger = QA-HOST-DEV01: Drive Space on E LOW QA-HOST-DEV01
    Trigger = BMSQL-HOST-QA01: Processor load is too high on BMSQL-HOST-QA01
    Trigger = BMSQL-HOST-QA01: Free disk space is less than 5% on volume G:
    Trigger = BMSQL-HOST-QA01: Lack of free memory on server BMSQL-HOST-QA01
    This is the operation in the action:
    Send message to users: XXXXXXXXXXXXXX, XXXXXXXXXXXX via Gmail2
    Start: Immediately
    Duration: Default
    Action: Edit/Remove
    The users are in a USER GROUP which is enabled and has read/write permissions to all host groups.
    The users also have media created a verified working.
    (I do apologize however I can not post screen shots to the thread for some reason.)
    I just can't make sense as to why some actions work and others don't.
    Any help would be greatly appreciated.
  • volter
    • Dec 2011
    • 85
    Take a look at the action audit log. If there's nothing in it, Zabbix came to the conslusion that it should not attempt so do something. A list of possible reasons is here: http://www.zabbix.org/wiki/Docs/acti...notified.3F.22
