Announcement
No announcement yet.
Zabbix Performance Problem
  • Filter
    I´m having huge performance problem with Zabbix Server since my NVPS has achieved the value of 3.500.
    However the problem starts only at midnight, sometimes 21 h, and fineshes 1 or 2 hours later. Sometimes it lasts more too.
    During this time, the items aren´t updated and some data is lost. The DBsyncers process stays very slow and
    the CPU I/O wait increase very much in the DB Server. The Zabbix Dashboard doen´t work too.
    At the DB server we can see a lot of queries like this one:
    select clock,ns,value from history_uint where itemid=<id> and clock><end> and clock<=<begin>
    During the day, the CPU utilization of the DB server is very low and everything works fine.
    Has anyone any idea what is happening at this hour and what can be done do solve this problem?
    Do you think that the problem is related with the DB Server or the Zabbix Server?
    I think that it is related with the dbsyncer processes, but I´m not sure.
    As my environment is very big, the debug level in the Zabbix Server is set to 2 (Error) and I couldn´t see anything.
    Nothing on the /var/log/messagestoo, on the DB Server.
    Thanks,
    Rodney
    My configuration is:
    - Zabbix Server version: 3.2.10
    - Zabbix Server host: Virtual Machine running CentOS 7.3.1611 64 bits, 4 vCPs, 16 GB RAM
    - Data Base: mysql Ver 15.1 Distrib 10.1.18-MariaDB, for Linux (x86_64) using readline 5.1. At the moment I´m with just one node.
    - Data Base host: Physical Host running CentOS 7.4.1708 (Core), 32 CPUs, 87 GB RAM
    - Several proxies version 3.2.10, on VMs CentOS 7.4.
    - Partition tables enable on history and trend tables.
    Zabbix Serve Configuration (main parameters changed):
    StartTrappers=100
    MaxHousekeeperDelete=100000
    CacheSize=1536M
    CacheUpdateFrequency=300
    StartDBSyncers=8 (should I increase it?)
    HistoryCacheSize=512M (during the problem, it goes to zero)
    TrendCacheSize=256M
    ValueCacheSize=1G
    Timeout=4
    LogSlowQueries=10000
    MariaDB Configuration:
    open_files_limit = 16364
    max_connections = 500
    binlog_format=ROW
    default_storage_engine=InnoDB
    innodb_autoinc_lock_mode=2
    innodb_flush_log_at_trx_commit=0
    innodb_additional_mem_pool_size = 16M
    innodb_autoextend_increment = 256
    innodb_buffer_pool_instances = 32
    innodb_buffer_pool_size = 32G
    innodb_change_buffer_max_size = 50
    innodb_concurrency_tickets = 5000
    innodb_file_per_table = 1
    innodb_flush_method = O_DIRECT
    innodb_log_file_size = 512M
    innodb_log_files_in_group = 4
    innodb_old_blocks_time = 1000
    innodb_open_files = 2048
    innodb_stats_on_metadata = OFF
    innodb_lock_wait_timeout = 50
    innodb_io_capacity = 2000
    large-pages
    binlog-row-event-max-size = 8192
    character_set_server = utf8
    collation_server = utf8_bin
    expire_logs_days = 1
    join_buffer_size = 262144
    max_allowed_packet = 32M
    max_connect_errors = 10000
    max_heap_table_size = 134217728
    query_cache_type = 0
    query_cache_size = 0
    slow-query-log = ON
    table_open_cache = 2048
    thread_cache_size = 64
    tmp_table_size = 134217728
    wait_timeout = 86400
    Take a look at "internal monitoring" before anything else: You probably already have the template assigned which ships with Zabbix!
    This article is old but describes the concept: http://blog.zabbix.com/monitoring-ho...esses-are/457/
    How big is your DB on disk? http://blog.zabbix.com/scalable-zabb...400-nvps/2615/ may also help you.
