v1.1.5 urgent bug !
  • dsipe
    • Oct 2006
    • 184
    v1.1.5 urgent bug !
    Our Zabbix server regularly stop working.
    The processes shut down with the following error inside zabbix_server.log :
    zabbix_server: comms.c:104: zbx_malloc: Assertion `size' failed.
    We cannot rely anymore on that product!
    URgent update needed to correct that problem cauz people becoming not confident with Zabbix!
  • dsipe
    • Oct 2006
    • 184
    i run a mysqlcheck --auto-repair on zabbix database and it looked better now
    • dimi
      • Nov 2004
      • 13
      Dear all i have found the same problem, using MySQL-4.1.11 i have also try as suggest "mysqlcheck zabbix --auto-repair" but i still have the problem:
      005551:20070202:102047 One server process died. Shutting down...
      What do you think?
      Many thanks for this great software.
      • dsipe
        • Oct 2006
        • 184
        i reverted back to 1.1.4 and everything's ok now.
        If using actions [ remote command or send message ], take care about using 1.1.5 new macros.
        I don't have enough time to make tests, but it look like a possible source of problem. To be more investigated
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          Fixed! Please upgrade to 1.1.6.
          Alexei Vladishev
          New York | Tokyo | Riga
          My Twitter
