Cant load zabbix pages in iframe anymore
  • ChainBlock
    • Dec 2017
    Hi Guys,
    We are using zabbix for a few years now. In our welcome hall we have a big screen with some rotated slides containing information about our it infrastructure. One of the slides contained an Iframe in which we loaded a specific zabbix screen.
    This always worked perfect till recently when we updated to the latest version of zabbix. Since then is not possible to load any zabbix page in an iframe. The iframes stay blank :'-(
    I've been searching if could find something add like SAMEORIGIN, X-FRAME-OPTIONS, CSP, ALLOW FROM, etc But i could not find anything that possible could have been added in one of the latest updates. I can't find also nothing about it in the releasenotes/changelogs.
    Does any one know if zabbix added this as a new security feature or maybe changed something in the httpd configuration? It there a way to get this fixed (or disabled)?
    Thanks in advance
  • pc-nico
    • May 2014
    • 29
    We use also a Frameset, at the top area Zabbix, at the buttom a newsticker and clock... since 3.4.4 zabbix sends a X-Frame Header....
    you can commant out the Line 131 in /usr/share/zabbix/include/page_header.php
    PHP Code:
    header('X-Frame-Options: '.$x_frame_options);
    but it is removed on every update, not so cool methode...
    better:
    you can use Addons in the Browser to ignore X-Frame Header
    for Chrome use: https://chrome.google.com/webstore/d...kamfmkohkpodhe
    works fine for us
    • versh_va
      • May 2017
      But why? And how it can be unset via zabbix interface or config files?
      It is not cool at all...
      • glebs.ivanovskis
        • Jul 2015
        • 237
        • Miks.Kronkalns
          • Mar 2017
          For reasons please see also https://support.zabbix.com/browse/ZBX-13133.
          Instead of commenting out line 131 in includes/page_header.php, it is better to change the value of X_FRAME_OPTIONS. Please take a look at section "HTTP headers" in include/defines.inc.php.
          • tuxmartin
            • Jan 2017
            • 12
            Changing X_FRAME_OPTIONS in /usr/share/zabbix/include/defines.inc.php does not work.
            PHP Code:
            // HTTP headers
             * Value of HTTP X-Frame-options header.
             * Supported options:
             *  - SAMEORIGIN (string) - compatible with rfc7034.
             *  - DENY (string) - compatible with rfc7034.
             *  - a list (string) of comma-separated hostnames. If hostname is not between allowed, the SAMEORIGIN option is used.
             *  - null - disable X-Frame-options header.
            define('X_FRAME_OPTIONS', 'SAMEORIGIN');
            //define('X_FRAME_OPTIONS', 'https://zabbix.example.net, https://app.clickup.com);
            You need to add two headers to nginx virtual host:
            add_header X-Frame-Options "ALLOW-FROM https://zabbix.example.net https://app.clickup.com";
            add_header Content-Security-Policy "frame-ancestors https://zabbix.example.net https://app.clickup.com";
            martin@martin:~$ curl -IL https://zabbix.example.net
            HTTP/2 200
            server: nginx/1.10.3 (Ubuntu)
            date: Mon, 23 Mar 2020 11:00:16 GMT
            content-type: text/html; charset=UTF-8
            set-cookie: PHPSESSID=lhlrdkagsjf19ir6blg80kc1lc; secure; HttpOnly
            expires: Thu, 19 Nov 1981 08:52:00 GMT
            cache-control: no-store, no-cache, must-revalidate
            pragma: no-cache
            x-content-type-options: nosniff
            x-xss-protection: 1; mode=block
            x-frame-options: SAMEORIGIN          # inserted by zabbix
            strict-transport-security: max-age=31557600
            x-frame-options: ALLOW-FROM https://zabbix.example.net https://app.clickup.com          # inserted by nginx
            content-security-policy: frame-ancestors https://zabbix.example.net https://app.clickup.com          # inserted by nginx
            • patrickdenis
              • May 2020
              • 18
              Indeed i added FALSE and still nothing...
              PHP Code:
              * The sandbox attribute enables an extra set of restrictions for the content in the iframe. Default is set to empty
              string, which means all restrictions are applied. To disable, set to FALSE. To set a specific set of restrictions,
              write a custom string.
              https://www.w3.org/TR/2010/WD-html5-20100624/the-iframe-element.html#attr-iframe-sandbox
              define('ZBX_IFRAME_SANDBOX', 'FALSE');
              // HTTP headers
              @tuxmatin so if i understand :
              1st address ""https://zabbix.example.net" is my host and second one "https://app.clickup.com" is the url I'm inserting in the URL widget ?
              Thank you in advance
              • fourstepper
                • Feb 2021
                We are also having issues embedding the Zabbix site on our company's dashboard after 5.2 upgrade from 5.0.
                We run Zabbix in docker, with the web interface behind a Traefik proxy.
                For security reasons, we are setting the Content-Security-Policy header to
                frame-ancestors 'self' http://internaldashboard.com;
                We have just learned that zabbix itself has some settings regarding iframe under General > Other, but we are having a hard time setting those up correctly.
                The main issue that we have come across is that while we are able to view the iframe which loads on our company dashboard, any login fails.
                The settings we have done under General > Other for now are :
                X-Frame-Options HTTP header: SAMEORIGIN and Use iframe sandboxing unchecked.
