Hi
I've found two actions that doesn't work when using the Zabbix front-end behind HAProxy:
Monitoring -> Maps -> Edit map -> Update
Configuration -> Hosts -> Toggle status on any host
Both of these operations work just find when the Zabbix front-end is not behind HAproxy.
Any way around this? I've been unable to find any information about it.
Haproxy config:
jsLoader.php?ver=3.4.4&lang=en_GB&showGuiMessaging=1&files[]=class.svg.canvas.js&files[]=class.svg.map.js&files[]=class.cmap.js&files[]=class.cviewswitcher.js&files[]=multiselect.js&files[]=servercheck.js:2461 Uncaught Error: Cannot update map.
at Object.error (jsLoader.php?ver=3.4.4&lang=en_GB&showGuiMessaging=1&files[]=class.svg.canvas.js&files[]=class.svg.map.js&files[]=class.cmap.js&files[]=class.cviewswitcher.js&files[]=multiselect.js&files[]=servercheck.js:2461)
at c (jsLoader.php?ver=3.4.4&lang=en_GB&showGuiMessaging=1:4978)
at Object.fireWith [as rejectWith] (jsLoader.php?ver=3.4.4&lang=en_GB&showGuiMessaging=1:4978)
at k (jsLoader.php?ver=3.4.4&lang=en_GB&showGuiMessaging=1:4980)
at XMLHttpRequest.r (jsLoader.php?ver=3.4.4&lang=en_GB&showGuiMessaging=1:4980)
Operation cannot be performed due to unauthorized request.
Haproxy config:
defaults
log global
mode http
option httplog
option dontlognull
option forwardfor
option http-server-close
frontend www-public
bind :::80 v4v6
# monitor
acl host_monitor hdr(host) -i monitor.my-domain
acl path_zabbiz path_dir -i zabbix
use_backend zabbix if host_monitor path_zabbiz
backend zabbix
server vm-monitor vm-monitor.local-domain
