Hi, Fabio. Pallotta,
By snmp you can monitor the AS400 with the templates that come with Zabbix "Template SNMP Device V1" and "Template SNMP Disks V1" for example.
You can also use the agent emulator that Constantin Oshmyan created with which you will get much more complete information.
