zabbix problem with media types, no emails
  • mrtplink
    • Dec 2017
    I have a problem with my zabbix server. (Zabbix 3.4.5)
    i configure auto registration on the server so that the hosts can registrate automatically on the server. all works fine until here.
    so i configure it that if a host use auto registration, the host will add to the server, than add to a group after this the host will disabled and the admin notify by email.
    everything works but no email arrives. under reports -> actions logs on the webinterface i can see nothing, the log is clear after some tests with auto registration.
    so now i modify this value in the zabbix_server.conf:
    # DebugLevel=3
    to this
    DebugLevel=4
    after this i restarted the zabbix service. NOW everything works and email send to the configure email adress. and i can see some values in the action log in the webinterface.
    but i think that's not correct or??
    any idea ?
    best regards & happy new year,
    Oliver
  • allexpetrov
    • May 2017
    • 361
    This one shouldn't be a problem because you've just changed the DebugLevel.
    After the restart, however, Zabbix fetched the fresh configuration from the Database. Have you modified the zabbix_server.conf file, especially the CacheUpdateFrequency= parameter?
    Regards,
    Alex!
    • mrtplink
      • Dec 2017
      Regards,
      Alex!
      Hi Alex,
      No, i only change the debug level value nothing else. any idea what i can do. zabbix is still sending no email. only if i change the debug level....
      best regards!
