SNMP not receiving data
  • dhl
    • Mar 2014
    • 9
    Hello
    I have a problem with SNMP. This is actually not a Zabbix problem, but as it causes errors in Zabbix too (missing data), I thought that may be someone around here can help me a bit.
    I have a lot of SNMP devices and mostly the monitoring works fine. Still I have few hosts that Zabbix fails to collect data from time to time. As data is still received few times per hour, I thought about network or the host itself being overloaded. So I did tcpdump to check for networking issues and this is where I got confused. I can see that Zabbix proxy sends "get request" and receives response, but still shows "timeout" in snmpwalk. For example:
    zabbix-proxy.mgmt:~ $ snmpbulkwalk -v 3 -u user -a MD5 -A auth -l authNoPriv host-x.mgmt .1.3.6.1.2.1.31.1.1.1.10
    Timeout: No Response from host-x.mgmt
    Bit of tcpdump at the same time:
    zabbix-proxy.mgmt:~ $ tcpdump -r /tmp/snmpdebug.pcap | grep 31.1.1.1.10
    reading from file /tmp/snmpdebug.pcap, link-type LINUX_SLL (Linux cooked)
    14:16:10.780974 IP zabbix-proxy.mgmt.46534 > host-x.mgmt.snmp:  F=ar U="user" E=_00_00_90_55_ae_0e_ad_01_80_00_00_c1 C="" GetBulk(30)  N=0 M=10 31.1.1.1.10
    14:16:12.782931 IP zabbix-proxy.mgmt.46534 > host-x.mgmt.snmp:  F=ar U="user" E=_00_00_90_55_ae_0e_ad_01_80_00_00_c1 C="" GetBulk(30)  N=0 M=10 31.1.1.1.10
    14:16:12.919682 IP host-x.mgmt.snmp > zabbix-proxy.mgmt.46534:  F=a U="user" E=_00_00_90_55_ae_0e_ad_01_80_00_00_c1 C="" GetResponse(263)  31.1.1.1.10.2134639363=38532361352997 31.1.1.1.10.2134639364=22003841887865 31.1.1.1.10.2134639490=0 31.1.1.1.10.2134639491=149588147286 31.1.1.1.10.2134647780=83613246992568 31.1.1.1.10.2134647781=98246014871898 31.1.1.1.10.2134672258=369772994858 31.1.1.1.10.2146632833=0 31.1.1.1.10.2146632834=0 31.1.1.1.10.2147238657=0
    14:16:14.783941 IP zabbix-proxy.mgmt.46534 > host-x.mgmt.snmp:  F=ar U="user" E=_00_00_90_55_ae_0e_ad_01_80_00_00_c1 C="" GetBulk(30)  N=0 M=10 31.1.1.1.10
    14:16:14.863256 IP host-x.mgmt.snmp > zabbix-proxy.mgmt.46534:  F=a U="user" E=_00_00_90_55_ae_0e_ad_01_80_00_00_c1 C="" GetResponse(263)  31.1.1.1.10.2134639363=38532361352997 31.1.1.1.10.2134639364=22003841887865 31.1.1.1.10.2134639490=0 31.1.1.1.10.2134639491=149588147286 31.1.1.1.10.2134647780=83613246992568 31.1.1.1.10.2134647781=98246014871898 31.1.1.1.10.2134672258=369773004133 31.1.1.1.10.2146632833=0 31.1.1.1.10.2146632834=0 31.1.1.1.10.2147238657=0
    14:16:16.784938 IP zabbix-proxy.mgmt.46534 > host-x.mgmt.snmp:  F=ar U="user" E=_00_00_90_55_ae_0e_ad_01_80_00_00_c1 C="" GetBulk(30)  N=0 M=10 31.1.1.1.10
    14:16:16.918551 IP host-x.mgmt.snmp > zabbix-proxy.mgmt.46534:  F=a U="user" E=_00_00_90_55_ae_0e_ad_01_80_00_00_c1 C="" GetResponse(263)  31.1.1.1.10.2134639363=38532363159218 31.1.1.1.10.2134639364=22003846646776 31.1.1.1.10.2134639490=0 31.1.1.1.10.2134639491=149588148986 31.1.1.1.10.2134647780=83613258103748 31.1.1.1.10.2134647781=98246019891033 31.1.1.1.10.2134672258=369773011016 31.1.1.1.10.2146632833=0 31.1.1.1.10.2146632834=0 31.1.1.1.10.2147238657=0
    14:16:18.786899 IP zabbix-proxy.mgmt.46534 > host-x.mgmt.snmp:  F=ar U="user" E=_00_00_90_55_ae_0e_ad_01_80_00_00_c1 C="" GetBulk(30)  N=0 M=10 31.1.1.1.10
    14:16:18.874084 IP host-x.mgmt.snmp > zabbix-proxy.mgmt.46534:  F=a U="user" E=_00_00_90_55_ae_0e_ad_01_80_00_00_c1 C="" GetResponse(263)  31.1.1.1.10.2134639363=38532364749243 31.1.1.1.10.2134639364=22003846646776 31.1.1.1.10.2134639490=0 31.1.1.1.10.2134639491=149588148986 31.1.1.1.10.2134647780=83613258103748 31.1.1.1.10.2134647781=98246019891033 31.1.1.1.10.2134672258=369773019373 31.1.1.1.10.2146632833=0 31.1.1.1.10.2146632834=0 31.1.1.1.10.2147238657=0
    14:16:20.801928 IP zabbix-proxy.mgmt.46534 > host-x.mgmt.snmp:  F=ar U="user" E=_00_00_90_55_ae_0e_ad_01_80_00_00_c1 C="" GetBulk(30)  N=0 M=10 31.1.1.1.10
    14:16:20.939664 IP host-x.mgmt.snmp > zabbix-proxy.mgmt.46534:  F=a U="user" E=_00_00_90_55_ae_0e_ad_01_80_00_00_c1 C="" GetResponse(263)  31.1.1.1.10.2134639363=38532366479595 31.1.1.1.10.2134639364=22003851364591 31.1.1.1.10.2134639490=0 31.1.1.1.10.2134639491=149588149894 31.1.1.1.10.2134647780=83613269580091 31.1.1.1.10.2134647781=98246024927683 31.1.1.1.10.2134672258=369773025972 31.1.1.1.10.2146632833=0 31.1.1.1.10.2146632834=0 31.1.1.1.10.2147238657=0
    Situation is same when using regular snmpwalk instead of bulk one.
    Further debugging led me to debug SNMP itself. Unfortunately I cannot understand most of the output, but difference I found in failed (timeout) response are those lines (first 8 lines repeat every time before those five retries):
    trace: _sess_process_packet(): snmp_api.c, 5314:
    sess_process_packet: unmatched msg id: 234799250 != 234799249
    trace: _sess_process_packet(): snmp_api.c, 5469:
    sess_process_packet: unhandled PDU
    trace: snmp_sess_select_info2_flags(): snmp_api.c, 6041:
    sess_select: for all sessions: 3 (to in 780937.066682 sec)
    verbose:sess_select: timer due in 1.910358 sec
    verbose:sess_select: setting timer to 1.910358 sec, clear block (was 1)
    trace: snmp_synch_input(): snmp_client.c, 183:
    snmp_synch: Response (ReqID: 811951478 - Cmd 165)
    Can someone point me out what else to check or what might be the problem?
    Raido
  • kaspars.mednis
    • Oct 2017
    • 349
    Hi Raido,
    lets first look what are your timeout settings in zabbix_server.conf file ? snmpV3 requests may take longer time than the default 4 seconds.
    Regards,
    Kaspars
    • dhl
      • Mar 2014
      • 9
      Hi Kaspars,
      Thank you for your reply.
      Before changing Timeout settings in zabbix conf, I would like to understand what's the actual problem with snmp. I'm getting timeouts with bare snmpwalk too (without zabbix involved). I've checked snmpwalk with setting timeout manually (adding option "-t") and still it got timeout from time to time no matter how long was the timeout period I set.
      My question is more like: why is snmpwalk showing timeout, while I can see the response coming through (even multiple times) via tcpdump? Is there some SNMP settings that I'm missing?
      Regards,
      Raido
      • jvanstijn
        • Jun 2016
        This sounds oddly like something I am experiencing. In my environment one of my hosts will just stop getting SNMP data over a period of time.
        snmpwalk to that particular host works fine. When I restart the host or the Zabbix server the problems go away.
        On another note (which makes Zabbix slightly more of a suspect as a culprit); the failing host(s) is/are consistent. It is/are always host X (and Y). If I add or remove another host to Zabbix however, the issue shifts to other host(s) that start to fail once in a while. The previous failing host(s) consequently work properly.
        Very odd.
        I shall investigate this further and try to post to this topic so others may find a solution.
        • patrick.ryan
          • Jun 2019
          I'm also experiencing something very similar to this. I have two hosts (network devices) that irregularly report no SNMP data. My attempts to correlate it to something else have turned up nothing. The problem occurs overnight when nearly nothing it going on on our network as well as in the middle of the day. I unfortunately can't contribute much at this point to the resolution of the problem but wanted to leave a post in case one of the previous posters was able to find more details.
