IPMI problems
  • bernaldopenas
    • Oct 2017
    • 13
    IPMI problems
    Hi:
    I'm triying to create a template with a lot of IPMI items, IPMI configuration it's ok cause i'm getting values.
    The problem that i have it's that i realiced that because of the number of IPMI items that i create in the template the only way of recieving all items it's to increase timeout in server config. With a timeout of 30 secs. everithing works ok, but with a regular time of 3, 4 secs. i just get 5 values, the rest of items become disabled.
    Do someone knows how can i tune this feature without increasing timeout?
    Best regards.
  • kaspars.mednis
    • Oct 2017
    • 349
    The possible problem - Zabbix is polling all the sensors one by one too often, your IPMI management hardware gets overloaded. (some kind of IPMI DoS attack)
    i see 2 possible solutions:
    1. Increase item refresh time.
    2. Look here https://www.zabbix.com/forum/archive...p/t-44968.html (it polls all sensors at once, then sends them to zabbix. I have used that before, very effective script), i think sources are here https://github.com/Volcano888/Volcan...ft-conf/Zabbix
    Use at your own risk, always go through all scripts to see what they are doing !
    Regards,
    Kaspars
    • bernaldopenas
      • Oct 2017
      • 13
      Thank for the response ... i'm triying to create my own scripts since i read
      ipmi-sensors(8) - Linux man page
      In order to prevent brute force attacks, some BMCs will temporarily "lock up" after a number of remote authentication errors. You may need to wait awhile in order to this temporary "lock up" to pass before you may authenticate again.
      • AndrewSummer
        • May 2017
        • 20
        Setting up IPMI Monitoring is really a pain in the...
        I even had IPMI Polling regulary crashing my Zabbix Server (3.2.7) on Ubuntu 16.04
        I monitor IPMI with max Timeout 30secs and an extra Zabbix Proxy dedicated to IPMI. But I still have a lot of gaps in the graphs... IPMI just sucks
        • AndrewSummer
          • May 2017
          • 20
          Well....
          Switched to Debian 9 for my IPMI Proxy and I am stunned:
          No gaps! Finally!
          So trying diffrent OSs and or IPMI Libs can make all the difference in the world...
