JMX monitoring issue on Zabbix-Java-gateway 3.0.14
  • rvempati
    • Jan 2018
    I am working to enable the JMX monitoring setup on an existing Zabbix Server which is on 3.0.14 version (CentOS 6).
    I have installed the Zabbix Java Gateway Version 3.0.14 on the same Zabbix Server and updated the configuration in zabbix_server.conf and zabbix_java_gateway.conf as mentioned in the documentation.
    I have configured the remote JMX interface on the Zabbix Web Interface and below is the error log that I could see in the zabbix_java_gateway.log
    2018-01-29 13:56:43.959 [pool-1-thread-3] DEBUG com.zabbix.gateway.SocketProcessor - starting to process incoming connection
    2018-01-29 13:56:43.959 [pool-1-thread-3] DEBUG c.z.gateway.BinaryProtocolSpeaker - reading Zabbix protocol header
    2018-01-29 13:56:43.960 [pool-1-thread-3] DEBUG c.z.gateway.BinaryProtocolSpeaker - reading 8 bytes of data length
    2018-01-29 13:56:43.960 [pool-1-thread-3] DEBUG c.z.gateway.BinaryProtocolSpeaker - reading 175 bytes of request data
    2018-01-29 13:56:43.960 [pool-1-thread-3] DEBUG c.z.gateway.BinaryProtocolSpeaker - received the following data in request: {"request":"java gateway jmx","conn":"172.25.108.157","port":8916,"username ":"monitorRole","password":"abcdef","keys":["jmx[\"java.lang:type=Memory\",HeapMemoryUsage.used]"]}
    2018-01-29 13:56:43.960 [pool-1-thread-3] DEBUG com.zabbix.gateway.SocketProcessor - dispatched request to class com.zabbix.gateway.JMXItemChecker
    2018-01-29 13:56:43.960 [pool-1-thread-3] DEBUG c.z.g.ZabbixJMXConnectorFactory - connecting to JMX agent at 'service:jmx:rmi:///jndi/rmi://[172.25.108.157]:8916/jmxrmi'
    2018-01-29 13:56:46.962 [pool-1-thread-3] WARN com.zabbix.gateway.SocketProcessor - error processing request
    com.zabbix.gateway.ZabbixException: java.net.SocketTimeoutException: connection timed out: service:jmx:rmi:///jndi/rmi://[172.25.108.157]:8916/jmxrmi
    at com.zabbix.gateway.JMXItemChecker.getValues(JMXIte mChecker.java:97) ~[zabbix-java-gateway-3.0.14.jar:na]
    at com.zabbix.gateway.SocketProcessor.run(SocketProce ssor.java:62) ~[zabbix-java-gateway-3.0.14.jar:na]
    at java.util.concurrent.ThreadPoolExecutor.runWorker( ThreadPoolExecutor.java:1149) [na:1.8.0_161]
    at java.util.concurrent.ThreadPoolExecutor$Worker.run (ThreadPoolExecutor.java:624) [na:1.8.0_161]
    at java.lang.Thread.run(Thread.java:748) [na:1.8.0_161]
    Caused by: java.net.SocketTimeoutException: connection timed out: service:jmx:rmi:///jndi/rmi://[172.25.108.157]:8916/jmxrmi
    at com.zabbix.gateway.ZabbixJMXConnectorFactory.conne ct(ZabbixJMXConnectorFactory.java:123) ~[zabbix-java-gateway-3.0.14.jar:na]
    at com.zabbix.gateway.JMXItemChecker.getValues(JMXIte mChecker.java:89) ~[zabbix-java-gateway-3.0.14.jar:na]
    ... 4 common frames omitted
    2018-01-29 13:56:46.962 [pool-1-thread-3] DEBUG c.z.gateway.BinaryProtocolSpeaker - sending the following data in response: {"response":"failed","error":"java.net.SocketTimeo utException: connection timed out: service:jmx:rmi:\/\/\/jndi\/rmi:\/\/[172.25.108.157]:8916\/jmxrmi"}
    2018-01-29 13:56:46.962 [pool-1-thread-3] DEBUG com.zabbix.gateway.SocketProcessor - finished processing incoming connection
    I am able to connect to the JMX interface that is configured in Zabbix via JConsole but it is with the Zabbix Java Gateway I am unable to connect.
    I suspect that the outgoing request mentioned in the log looks incorrect as the remote server IP is appended with closed brackets
    Can any one help me here if the above request framing by Java Gateway is resulting in the error? I have checked all the configuration and I couldn't find any reference to the remote server IP which is appended with closed brackets.
    Regards,
  • rvempati
    • Jan 2018
    Issue can be marked as resolved. I implemented below solution and it worked.
    Join the friendly and open Zabbix community on our forums and social media platforms.
