JMX agent failing
  • itsmenaveen
    • Feb 2018
    JMX agent failing
    I'm trying to connect JMX running in remote server, But not able to.
    1. Logs :
    com.zabbix.gateway.ZabbixException: org.json.JSONException: No value for jmx_endpoint
    at com.zabbix.gateway.JMXItemChecker.<init>(JMXItemCh ecker.java:71) ~[zabbix-java-gateway-3.4.6.jar:na]
    at com.zabbix.gateway.SocketProcessor.run(SocketProce ssor.java:58) ~[zabbix-java-gateway-3.4.6.jar:na]
    at java.util.concurrent.ThreadPoolExecutor.runWorker( ThreadPoolExecutor.java:1145) [na:1.7.0_101]
    at java.util.concurrent.ThreadPoolExecutor$Worker.run (ThreadPoolExecutor.java:615) [na:1.7.0_101]
    at java.lang.Thread.run(Thread.java:745) [na:1.7.0_101]
    Caused by: org.json.JSONException: No value for jmx_endpoint
    at org.json.JSONObject.get(JSONObject.java:354) ~[android-json-4.3_r3.1.jar:na]
    at org.json.JSONObject.getString(JSONObject.java:514) ~[android-json-4.3_r3.1.jar:na]
    at com.zabbix.gateway.JMXItemChecker.<init>(JMXItemCh ecker.java:59) ~[zabbix-java-gateway-3.4.6.jar:na]
    ... 4 common frames omitted
    2. zabbix_java_gateway.conf installed at remote server only has
    START_POLLERS=5
    Rest are defaults.
    3. At Zabbix server in zabbix_server.conf
    ### Option: JavaGateway
    # IP address (or hostname) of Zabbix Java gateway.
    # Only required if Java pollers are started.
    # Mandatory: no
    # Default:
    # JavaGateway=
    JavaGateway=10.255.36.131
    ### Option: JavaGatewayPort
    # Port that Zabbix Java gateway listens on.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # JavaGatewayPort=10052
    ### Option: StartJavaPollers
    # Number of pre-forked instances of Java pollers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartJavaPollers=0
    StartJavaPollers=5
    Can someone please help me identifying the root cause for the error?
