Zabbix 3.2 - HouseKeeping
  • pradeepspa
    • Aug 2016
    • 27
    #16
    Originally posted by tcilmo
    My bad, we use MySQL so that is where my brain went. Under Administration > General > Housekeeping (drop down on left hand side of screen).
    Here you can enable\disable housekeeping on different items suck as history and trends. Keep in mind if you disable house keeping on history and trends and if you don't use partitioning your database will grow until you run out of disk.
    Thank you. This is much helpful.I see in "Data Storage Period" on "History" section it shows as days but all my items is configured for 30 days.Is there a conflict? if so which one will take over?
    • tcilmo
      • Nov 2016
      • 122
      #17
      If housekeeping is enabled on history, and the "override item history history period" is checked, that value for data storage period directly below is applied. If "override item history history period" is not checked, the value in the item is applied.
      When housekeeping is disabled, neither value is applied thus the database will keep on growing.
      • pradeepspa
        • Aug 2016
        • 27
        #18
        Awesome. Thanks.
