Too many processes on zabbixserver
  • hernan
    • Sep 2016
    • 67
    Hello Team,
    Problem description:
    I received the following error message on the Zabbix Server:
    "Too many processes on zabbixserver"
    I checked the process running on the machine and I found that the Zabbix Server has 1397 process running:
    ~$ ps -ef | awk '{ print $8 }' | sort -n | uniq -c | sort -n | tail -5
    3 lightdm
    5 /usr/sbin/zabbix_agentd:
    6 /sbin/getty
    11 /usr/sbin/apache2
    1397 /usr/sbin/zabbix_server:
    Can you help me to solve this issue?
    Thanks in advance.
    Regards.
  • LenR
    • Sep 2009
    • 1011
    The "too many processes" trigger is a sample in the default template, it's only a starting point. Depending on the number of pollers and other things in your zabbix_server.conf, you will expect to have a LOT of processes on your zabbix server.
    If you want the alert, clone the trigger on this box, set the limit to 1450 or so, then disable the standard trigger; or just disable the original trigger.
    Linux will have a number of procs per core by default, I think it's 3, so if you have a 24 core box, that's 72 procs just for the kernel.
    • hernan
      • Sep 2016
      • 67
      Thank you LenR !!! I will follow your suggestion on my environment.
      Regards.
      • volter
        • Dec 2011
        • 85
        1400 zabbix_server processes?
        • LenR
          • Sep 2009
          • 1011
          Yea, second thought, that is a LOT, my server is about 350 and about that on several proxies. I guess if we tried to run ALL of it on the server, it could add up, but it probably wouldn't run right.
          • volter
            • Dec 2011
            • 85
            Take a good look at your configuration. You probably configured way too many workers of some kind. Also keep in mind that each of them has a permanent database connection!
            • kloczek
              • Jun 2006
              • 1771
              Originally posted by volter
              Take a good look at your configuration. You probably configured way too many workers of some kind. Also, keep in mind that each of them has a permanent database connection!
              More likely he increased the number of pollers to with growing number of hosts and passive items to monitor.
              If it is the case he needs to switch from passive monitoring to active one.
              Passive monitoring does not scale well.
              The second thing is adding the proxy. Even with only one proxy is possible to minimize losses of monitoring data during the server restart.
