"zabbix-server start" result "stop/pre-start" but can start manually...
  • theWoosh
    • Nov 2015
    • 20
    Hi I'm on ubuntu 14.04 and installed zabbix 3.02 server & agent way back and it worked fine but haven't had occasion to look at it for ages.
    Now when I do I find that the zabbix-server isn't working and when I try to start it with "service zabbix-server start" it responds 'stop/pre-start'.
    Presumably something has been broken during routine upgrades...
    No log file is being produced and the process number it gives doesn't exist...
    I am able to start zabbix-server manually from the command line with "zabbix_server" and this produces a log file in the right place and logs to it...
    Any ideas how to debug the script? Without a logfile I don't even know where to start!
    zabbix_server.conf looks like this (and the zabbix_agent script, which works, is identical except for agent not server):
    # This is a configuration file for Zabbix server daemon
    # To get more information about Zabbix, visit http://www.zabbix.com
    ### Option: ListenPort
    # Listen port for trapper.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # ListenPort=10051
    ### Option: SourceIP
    # Source IP address for outgoing connections.
    # Mandatory: no
    # Default:
    # SourceIP=
    ### Option: LogType
    # Specifies where log messages are written to:
    # system - syslog
    # file - file specified with LogFile parameter
    # console - standard output
    # Mandatory: no
    # Default:
    # LogType=file
    ### Option: LogFile
    # Log file name for LogType 'file' parameter.
    # Mandatory: no
    # Default:
    # LogFile=
    LogFile=/var/log/zabbix/zabbix_server.log
    ### Option: LogFileSize
    # Maximum size of log file in MB.
    # 0 - disable automatic log rotation.
    # Mandatory: no
    # Range: 0-1024
    # Default:
    # LogFileSize=1
    LogFileSize=5
    ### Option: DebugLevel
    # Specifies debug level:
    # 0 - basic information about starting and stopping of Zabbix processes
    # 1 - critical information
    # 2 - error information
    # 3 - warnings
    # 4 - for debugging (produces lots of information)
    # 5 - extended debugging (produces even more information)
    # Mandatory: no
    # Range: 0-5
    # Default:
    # DebugLevel=3
    DebugLevel=4
    ### Option: PidFile
    # Name of PID file.
    # Mandatory: no
    # Default:
    # PidFile=/tmp/zabbix_server.pid
    PidFile=/var/run/zabbix/zabbix_server.pid
    ### Option: DBHost
    # Database host name.
    # If set to localhost, socket is used for MySQL.
    # If set to empty string, socket is used for PostgreSQL.
    # Mandatory: no
    # Default:
    DBHost=localhost
    ### Option: DBName
    # Database name.
    # For SQLite3 path to database file must be provided. DBUser and DBPassword are ignored.
    # Mandatory: yes
    # Default:
    DBName=#####
    ### Option: DBSchema
    # Schema name. Used for IBM DB2 and PostgreSQL.
    # Mandatory: no
    # Default:
    # DBSchema=
    ### Option: DBUser
    # Database user. Ignored for SQLite.
    # Mandatory: no
    # Default:
    # DBUser=
    DBUser=#####
    ### Option: DBPassword
    # Database password. Ignored for SQLite.
    # Comment this line if no password is used.
    # Mandatory: no
    # Default:
    # DBPassword=
    DBPassword=######
    ### Option: DBSocket
    # Path to MySQL socket.
    # Mandatory: no
    # Default:
    # DBSocket=/tmp/mysql.sock
    ### Option: DBPort
    # Database port when not using local socket. Ignored for SQLite.
    # Mandatory: no
    # Range: 1024-65535
    # Default (for MySQL):
    # DBPort=3306
    ############ ADVANCED PARAMETERS ################
    ### Option: StartPollers
    # Number of pre-forked instances of pollers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartPollers=5
    ### Option: StartIPMIPollers
    # Number of pre-forked instances of IPMI pollers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartIPMIPollers=0
    ### Option: StartPollersUnreachable
    # Number of pre-forked instances of pollers for unreachable hosts (including IPMI and Java).
    # At least one poller for unreachable hosts must be running if regular, IPMI or Java pollers
    # are started.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartPollersUnreachable=1
    ### Option: StartTrappers
    # Number of pre-forked instances of trappers.
    # Trappers accept incoming connections from Zabbix sender, active agents and active proxies.
    # At least one trapper process must be running to display server availability and view queue
    # in the frontend.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartTrappers=5
    ### Option: StartPingers
    # Number of pre-forked instances of ICMP pingers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartPingers=1
    ### Option: StartDiscoverers
    # Number of pre-forked instances of discoverers.
    # Mandatory: no
    # Range: 0-250
    # Default:
    # StartDiscoverers=1
    ### Option: StartHTTPPollers
    # Number of pre-forked instances of HTTP pollers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartHTTPPollers=1
    ### Option: StartTimers
    # Number of pre-forked instances of timers.
    # Timers process time-based trigger functions and maintenance periods.
    # Only the first timer process handles the maintenance periods.
    # Mandatory: no
    # Range: 1-1000
    # Default:
    # StartTimers=1
    ### Option: StartEscalators
    # Number of pre-forked instances of escalators.
    # Mandatory: no
    # Range: 0-100
    # Default:
    # StartEscalators=1
    ### Option: JavaGateway
    # IP address (or hostname) of Zabbix Java gateway.
    # Only required if Java pollers are started.
    # Mandatory: no
    # Default:
    # JavaGateway=
    ### Option: JavaGatewayPort
    # Port that Zabbix Java gateway listens on.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # JavaGatewayPort=10052
    ### Option: StartJavaPollers
    # Number of pre-forked instances of Java pollers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartJavaPollers=0
    ### Option: StartVMwareCollectors
    # Number of pre-forked vmware collector instances.
    # Mandatory: no
    # Range: 0-250
    # Default:
    # StartVMwareCollectors=0
    ### Option: VMwareFrequency
    # How often Zabbix will connect to VMware service to obtain a new data.
    # Mandatory: no
    # Range: 10-86400
    # Default:
    # VMwareFrequency=60
    ### Option: VMwarePerfFrequency
    # How often Zabbix will connect to VMware service to obtain performance data.
    # Mandatory: no
    # Range: 10-86400
    # Default:
    # VMwarePerfFrequency=60
    ### Option: VMwareCacheSize
    # Size of VMware cache, in bytes.
    # Shared memory size for storing VMware data.
    # Only used if VMware collectors are started.
    # Mandatory: no
    # Range: 256K-2G
    # Default:
    # VMwareCacheSize=8M
    ### Option: VMwareTimeout
    # Specifies how many seconds vmware collector waits for response from VMware service.
    # Mandatory: no
    # Range: 1-300
    # Default:
    # VMwareTimeout=10
    ### Option: SNMPTrapperFile
    # Temporary file used for passing data from SNMP trap daemon to the server.
    # Must be the same as in zabbix_trap_receiver.pl or SNMPTT configuration file.
    # Mandatory: no
    # Default:
    # SNMPTrapperFile=/tmp/zabbix_traps.tmp
    ### Option: StartSNMPTrapper
    # If 1, SNMP trapper process is started.
    # Mandatory: no
    # Range: 0-1
    # Default:
    # StartSNMPTrapper=0
    ### Option: ListenIP
    # List of comma delimited IP addresses that the trapper should listen on.
    # Trapper will listen on all network interfaces if this parameter is missing.
    # Mandatory: no
    # Default:
    # ListenIP=0.0.0.0
    # ListenIP=127.0.0.1
    ### Option: HousekeepingFrequency
    # How often Zabbix will perform housekeeping procedure (in hours).
    # Housekeeping is removing outdated information from the database.
    # To prevent Housekeeper from being overloaded, no more than 4 times HousekeepingFrequency
    # hours of outdated information are deleted in one housekeeping cycle, for each item.
    # To lower load on server startup housekeeping is postponed for 30 minutes after server start.
    # With HousekeepingFrequency=0 the housekeeper can be only executed using the runtime control option.
    # In this case the period of outdated information deleted in one housekeeping cycle is 4 times the
    # period since the last housekeeping cycle, but not less than 4 hours and not greater than 4 days.
    # Mandatory: no
    # Range: 0-24
    # Default:
    # HousekeepingFrequency=1
    ### Option: MaxHousekeeperDelete
    # The table "housekeeper" contains "tasks" for housekeeping procedure in the format:
    # [housekeeperid], [tablename], [field], [value].
    # No more than 'MaxHousekeeperDelete' rows (corresponding to [tablename], [field], [value])
    # will be deleted per one task in one housekeeping cycle.
    # SQLite3 does not use this parameter, deletes all corresponding rows without a limit.
    # If set to 0 then no limit is used at all. In this case you must know what you are doing!
    # Mandatory: no
    # Range: 0-1000000
    # Default:
    # MaxHousekeeperDelete=5000
    ### Option: SenderFrequency
    # How often Zabbix will try to send unsent alerts (in seconds).
    # Mandatory: no
    # Range: 5-3600
    # Default:
    # SenderFrequency=30
    ### Option: CacheSize
    # Size of configuration cache, in bytes.
    # Shared memory size for storing host, item and trigger data.
    # Mandatory: no
    # Range: 128K-8G
    # Default:
    # CacheSize=8M
    ### Option: CacheUpdateFrequency
    # How often Zabbix will perform update of configuration cache, in seconds.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # CacheUpdateFrequency=60
    ### Option: StartDBSyncers
    # Number of pre-forked instances of DB Syncers.
    # Mandatory: no
    # Range: 1-100
    # Default:
    # StartDBSyncers=4
    ### Option: HistoryCacheSize
    # Size of history cache, in bytes.
    # Shared memory size for storing history data.
    # Mandatory: no
    # Range: 128K-2G
    # Default:
    # HistoryCacheSize=16M
    ### Option: HistoryIndexCacheSize
    # Size of history index cache, in bytes.
    # Shared memory size for indexing history cache.
    # Mandatory: no
    # Range: 128K-2G
    # Default:
    # HistoryIndexCacheSize=4M
    ### Option: TrendCacheSize
    # Size of trend cache, in bytes.
    # Shared memory size for storing trends data.
    # Mandatory: no
    # Range: 128K-2G
    # Default:
    # TrendCacheSize=4M
    ### Option: ValueCacheSize
    # Size of history value cache, in bytes.
    # Shared memory size for caching item history data requests.
    # Setting to 0 disables value cache.
    # Mandatory: no
    # Range: 0,128K-64G
    # Default:
    # ValueCacheSize=8M
    ### Option: Timeout
    # Specifies how long we wait for agent, SNMP device or external check (in seconds).
    # Mandatory: no
    # Range: 1-30
    # Default:
    # Timeout=3
    Timeout=4
    ### Option: TrapperTimeout
    # Specifies how many seconds trapper may spend processing new data.
    # Mandatory: no
    # Range: 1-300
    # Default:
    # TrapperTimeout=300
    ### Option: UnreachablePeriod
    # After how many seconds of unreachability treat a host as unavailable.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # UnreachablePeriod=45
    ### Option: UnavailableDelay
    # How often host is checked for availability during the unavailability period, in seconds.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # UnavailableDelay=60
    ### Option: UnreachableDelay
    # How often host is checked for availability during the unreachability period, in seconds.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # UnreachableDelay=15
    ### Option: AlertScriptsPath
    # Full path to location of custom alert scripts.
    # Default depends on compilation options.
    # Mandatory: no
    # Default:
    # AlertScriptsPath=${datadir}/zabbix/alertscripts
    AlertScriptsPath=/usr/lib/zabbix/alertscripts
    ### Option: ExternalScripts
    # Full path to location of external scripts.
    # Mandatory: no
    # Default:
    # ExternalScripts=${datadir}/zabbix/externalscripts
    ExternalScripts=/usr/lib/zabbix/externalscripts
    ### Option: FpingLocation
    # Location of fping.
    # Make sure that fping binary has root ownership and SUID flag set.
    # Mandatory: no
    # Default:
    # FpingLocation=/usr/sbin/fping
    FpingLocation=/usr/bin/fping
    ### Option: Fping6Location
    # Location of fping6.
    # Make sure that fping6 binary has root ownership and SUID flag set.
    # Make empty if your fping utility is capable to process IPv6 addresses.
    # Mandatory: no
    # Default:
    # Fping6Location=/usr/sbin/fping6
    Fping6Location=/usr/bin/fping6
    ### Option: SSHKeyLocation
    # Location of public and private keys for SSH checks and actions.
    # Mandatory: no
    # Default:
    # SSHKeyLocation=
    ### Option: LogSlowQueries
    # How long a database query may take before being logged (in milliseconds).
    # Only works if DebugLevel set to 3, 4 or 5.
    # 0 - don't log slow queries.
    # Mandatory: no
    # Range: 1-3600000
    # Default:
    # LogSlowQueries=0
    LogSlowQueries=3000
    ### Option: TmpDir
    # Temporary directory.
    # Mandatory: no
    # Default:
    # TmpDir=/tmp
    ### Option: StartProxyPollers
    # Number of pre-forked instances of pollers for passive proxies.
    # Mandatory: no
    # Range: 0-250
    # Default:
    # StartProxyPollers=1
    ### Option: ProxyConfigFrequency
    # How often Zabbix Server sends configuration data to a Zabbix Proxy in seconds.
    # This parameter is used only for proxies in the passive mode.
    # Mandatory: no
    # Range: 1-3600*24*7
    # Default:
    # ProxyConfigFrequency=3600
    ### Option: ProxyDataFrequency
    # How often Zabbix Server requests history data from a Zabbix Proxy in seconds.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # ProxyDataFrequency=1
    ### Option: AllowRoot
    # Allow the server to run as 'root'. If disabled and the server is started by 'root', the server
    # will try to switch to the user specified by the User configuration option instead.
    # Has no effect if started under a regular user.
    # 0 - do not allow
    # 1 - allow
    # Mandatory: no
    # Default:
    # AllowRoot=0
    ### Option: User
    # Drop privileges to a specific, existing user on the system.
    # Only has effect if run as 'root' and AllowRoot is disabled.
    # Mandatory: no
    # Default:
    # User=zabbix
    ### Option: Include
    # You may include individual files or all files in a directory in the configuration file.
    # Installing Zabbix will create include directory in /usr/local/etc, unless modified during the compile time.
    # Mandatory: no
    # Default:
    # Include=
    # Include=/usr/local/etc/zabbix_server.general.conf
    # Include=/usr/local/etc/zabbix_server.conf.d/
    # Include=/usr/local/etc/zabbix_server.conf.d/*.conf
    ### Option: SSLCertLocation
    # Location of SSL client certificates.
    # This parameter is used only in web monitoring.
    # Mandatory: no
    # Default:
    # SSLCertLocation=${datadir}/zabbix/ssl/certs
    ### Option: SSLKeyLocation
    # Location of private keys for SSL client certificates.
    # Mandatory: no
    # Default:
    # SSLKeyLocation=${datadir}/zabbix/ssl/keys
    ### Option: SSLCALocation
    # Override the location of certificate authority (CA) files for SSL server certificate verification.
    # If not set, system-wide directory will be used.
    # This parameter is used only in web monitoring and SMTP authentication.
    # Mandatory: no
    # Default:
    # SSLCALocation=
    ####### LOADABLE MODULES #######
    ### Option: LoadModulePath
    # Full path to location of server modules.
    # Mandatory: no
    # Default:
    # LoadModulePath=${libdir}/modules
    # Module to load at server startup. Modules are used to extend functionality of the server.
    # Format: LoadModule=<module.so>
    # The modules must be located in directory specified by LoadModulePath.
    # It is allowed to include multiple LoadModule parameters.
    # Mandatory: no
    # Default:
    # LoadModule=
    ####### TLS-RELATED PARAMETERS #######
    ### Option: TLSCAFile
    # Full pathname of a file containing the top-level CA(s) certificates for
    # peer certificate verification.
    # Mandatory: no
    # Default:
    # TLSCAFile=
    ### Option: TLSCRLFile
    # Full pathname of a file containing the server private key.
    # Mandatory: no
    # Default:
    # TLSKeyFile=
  • volter
    • Dec 2011
    • 85
    Try zabbx_server -f -c <that_configuration_file>, or is that what you did?
    • theWoosh
      • Nov 2015
      • 20
      thanks volter - I hadn't tried that but it just works fine
      when I execute it like this:
      # runuser -l zabbix /usr/sbin/zabbix_server -f -c /etc/zabbix/zabbix_server.conf If I run it as root it tells me it can't run as root even though I have the user option set...
      I'm pretty sure there must be something wrong in the /etc/initd/zabbix-server script...
