Zabbix java gateway on Debian 9
  • stepassia
    • Feb 2018
    • 27
    Hi to all, I'm trying to install the Java gateway on my Zabbix Server (Debian 8).
    If I try to execute apt-get install zabbix-java-gateway I got the error in image.
    download failed
    Oracle JDK 6 is NOT installed.
    dpkg: error processing package oracle-java6-installer (--configure):
    subprocess installed post-installation script returned error exit status 1
    Errors were encountered while processing:
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    Whats wrong?
  • volter
    • Dec 2011
    • 85
    As apt-get clearly indicates, the Gateway actually is already installed. Your distribution most likely doesn't ship with an Oracle repo configured by default. What is more Java 6 is stone old and you can go with openjdk too.
    • stepassia
      • Feb 2018
      • 27
      Ok, thanks!
