Job for zabbix-agent.service failed because a configured resource limit was exceeded
  • mitch2k
    • Mar 2018
    • 14
    I just noticed that my zabbix (active) agent on 1 of my servers was not running for a couple of weeks.
    Manually starting the service I get:
    [root@bezaweb03 ~]# systemctl status zabbix-agent.service
    ● zabbix-agent.service - Zabbix Agent
       Loaded: loaded (/usr/lib/systemd/system/zabbix-agent.service; enabled; vendor preset: disabled)
       Active: activating (auto-restart) (Result: resources) since Sat 2018-03-03 09:32:22 CET; 6s ago
      Process: 20407 ExecStart=/usr/sbin/zabbix_agentd -c $CONFFILE (code=exited, status=0/SUCCESS)
    Mar 03 09:32:22 server.com systemd[1]: Failed to start Zabbix Agent.
    Mar 03 09:32:22 server.com systemd[1]: Unit zabbix-agent.service entered failed state.
    Mar 03 09:32:22 server.com systemd[1]: zabbix-agent.service failed.
    [root@bezaweb03 ~]# systemctl start zabbix-agent.service
    Job for zabbix-agent.service failed because a configured resource limit was exceeded. See "systemctl status zabbix-agent.service" and "journalctl -xe" for details.
    [root@bezaweb03 ~]#
       Active: activating (auto-restart) (Result: resources) since Sat 2018-03-03 09:38:20 CET; 5s ago
      Process: 22351 ExecStart=/usr/sbin/zabbix_agentd -c $CONFFILE (code=exited, status=0/SUCCESS)
    Mar 03 09:38:20 server.com systemd[1]: zabbix-agent.service never wrote its PID file. Failing.
    Mar 03 09:38:20 server.com systemd[1]: Failed to start Zabbix Agent.
    Mar 03 09:38:20 server.com systemd[1]: Unit zabbix-agent.service entered failed state.
    Mar 03 09:38:20 server.com systemd[1]: zabbix-agent.service failed.
    Reading trough the documentation, this appears to be a selinux issue. However, selinux is disabled...
    [root@bezaweb03 ~]# sestatus
    SELinux status:                 disabled
    This system is running CloudLinux 7.4.
    Any ideas how I can fix this?
    Apart from that, what is the appropriate method to monitor if the agent is dead?
    I have added an Agent Ping item to my template:
    And a trigger:
    But it does not seem to trigger, as the item does not get data:
    Thanks!
  • Atsushi
    • Aug 2013
    • 2028
    Have you restarted the OS after changing SELinux setting to disabled?
    • kloczek
      • Jun 2006
      • 1771
      Just check agent logs (/var/lig/zabbix/zabbix_agentd.log)
      • mitch2k
        • Mar 2018
        • 14
        /var/log/zabbix/zabbix_agentd.log is just empty
        I had restarted it before, but tried again to be sure:
        [root@bezaweb03 ~]#
        [root@bezaweb03 ~]# uptime
         09:02:26 up 2 min,  1 user,  load average: 1.01, 0.58, 0.22
        [root@bezaweb03 ~]# service zabbix-agent start
        Redirecting to /bin/systemctl start zabbix-agent.service
        [root@bezaweb03 ~]#
        • Atsushi
          • Aug 2013
          • 2028
          Set SELinux to disabled or set the policy.
          After changing the SELinux configuration file to disabled, it is necessary to restart the OS.
          • mitch2k
            • Mar 2018
            • 14
            Yeah, but selinux status IS disabled, and the server was restarted...
            • mitch2k
              • Mar 2018
              • 14
              I was able to troubleshoot the issue with some help. Apparantly there was a ACL issue which prevented the zabbix user to write to the log file.
              After changing the ACL, zabbix can start again.
              • Helaly
                • Aug 2018
                can you please explain more ?
                • meloferz
                  • Oct 2018
                  I had the same issue with acl, what i've done was the following:
                  cd /var/log
                  mkdir zabbix
                  chown -c zabbix:zabbix zabbix
                  getfacl zabbix (to confirm that the ownership and group are for zabbix)
                  done
                  • Ravikumar
                    • Jun 2018
                    I had same issue, it is just log file owner issue.
                    [ac@machine1~] ls - /var/log/zabbix/zabbix_agentd.log
                    -rw-rw-r-- 1 root root 2714 Jul 10 17:16 /var/log/zabbix/zabbix_agentd.log
                    [ac@machine1~] chown zabbix.zabbix /var/log/zabbix/zabbix_agentd.log
                    [ac@machine1~] systemctl start zabbix-agentd
                    done
