Deleted some files
  • strommen
    • Mar 2018
    Deleted some files
    Hello everyone! My first post, so bear with me
    I had som issues logging in to my fresh Zabbix installation on Ubuntu, so I decided to delete everything and try to install it all over again. In that process I noticed som files and folders related to Zabbix which i deleted manually. After reinstall and setting up sql etc, i only get a 404 - Not found when I try to access the web interface.
    Can someone help me out? I hoped these files would reappear after installing it again, but no. I guess I have to replace the files manually, but not sure how...
    I deleted these folders including files:
    /var/lib/zabbix/
    /var/log/zabbix/
    /var/run/zabbix/
    /etc/zabbix/
    /user/share/zabbix/
  • volter
    • Dec 2011
    • 85
    Did you install from packages? If so, try to reinstall them.
