big values in graphs
  • ProTON
    • Oct 2005
    • 77
    I have a graph where I monitor filesystem usage on one of my hard disk arrays. If I select 1 or 2 days worth of data, it is shown correctly. I see 5.2TB usage and this is true. However, when I select 3 or more days graph shows only ~930GB usage.
    Item configuration is as follows:
    Numeric (64bits)
    Bytes
    Custom multiplier of 8192
    Store value as is
    Show value as is
  • bbrendon
    • Sep 2005
    • 873
    I have a windows volume that has 1.8 TB free. 24 hour graph is fine but a 1 week graph shows 930 GB, which is definitely wrong.
    Anyone know whats up with this?
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • ProTON
      • Oct 2005
      • 77
      I think PHP backend is hitting the top somewhere. From the PHP manual "The maximum signed integer value for 64 bit systems is 9223372036854775807."
      • James Wells
        • Jun 2005
        • 664
        Greetings,
        Are you storing the data as a differential or as is?
        Unofficial Zabbix Developer
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          May I ask for a couple of screenshots, 24h and 1 week? Thanks.
          Alexei Vladishev
          New York | Tokyo | Riga
          My Twitter
          • ProTON
            • Oct 2005
            • 77
            Data stored as is.
            Screenshots attached.
            • bbrendon
              • Sep 2005
              • 873
              Hah. My Weekview is exactly the same. The green line is at 931.32 as well as min, max, and last.
              I store it as it.
              Stored as is, Integer, units are "B"
              • ProTON
                • Oct 2005
                • 77
                Patch submitted at http://www.zabbix.com/forum/showthread.php?p=21350
                Cheers!
