The configuration has been a big Mess!!
I have been getting the follwoing problems.
I am running Red Fat Linux, Fedora.
I installed version 1.1.6 and then moved to verison 1.3.2 when the earlier did not work.
But both the versions have the same problems.
Here are the problems that i am facing:
1). After the configuration, when i start up the Zabbis server and the client agent.
I start the Webn Browser to point to the Zabbix URL :
http://localhost:8080/zabbix
I am redirected to the main login page and on the header of the page, i see the follownig error :
Error in query [select * from rights where userid=2] [Unknown column 'userid' in 'where clause']
2). According to the manual for installation, after setting up the client and the server, i should be starting up the web interface, and shoudl point to the Zabbix URL.
but which URL is it talking about ?
if its talking about this URL,
but using this, the login page opens.
I dont know the URL of the liscene and configuration page.
Please help me with that one also.
