when I try to initiate daemon zabbix-server appears the following message:
debianteste:/var/log/zabbix# /etc/init.d/zabbix-server start
Starting Zabbix server checktables Qua Fev 28 14:23:11 GMT+3 2007
acknowledges<ok>,actions<ok>,alarms<ok>,alerts<ok> ,applications<ok>,auditlog<ok>,autoreg<ok>,conditi ons<ok>,config<ok>,functions<ok>,graphs<ok>,graphs _items<ok>,groups<ok>,help_items<ok>,history<ok>,h istory_log<ok>,history_str<ok>,history_text<ok>,hi story_uint<ok>,hosts<ok>,hosts_groups<ok>,hosts_pr ofiles<ok>,hosts_templates<ok>,housekeeper<ok>,ima ges<ok>,items<ok>,items_applications<ok>,mappings< ok>,media<ok>,media_type<ok>,profiles<ok>,rights<o k>,screens<ok>,screens_items<ok>,service_alarms<ok >,services<ok>,services_links<ok>,sessions<ok>,sys maps<ok>,sysmaps_elements<ok>,sysmaps_links<ok>,tr ends<ok>,trigger_depends<ok>,triggers<ok>,users<ok >,users_groups<ok>,usrgrp<ok>,valuemaps<ok>,zabbix _server /var/run/zabbix/server.pid seems to be stolen. Removing..
check_server /etc/init.d/zabbix-server: line 98: kill: (8135) - Processo inexistente
/var/run/zabbix/check_server.pid seems to be stolen. Removing..
this and normal?
verifying log of zabbix I see the following error
debianteste:/var/log/zabbix# cat server.log
008127:20070228:141510 Starting zabbix_server. ZABBIX 1.1.
008127:20070228:141510 Failed to connect to database: Error: Client does not support authentication protocol requested by server; consider upgrading MySQL client
I am with the installed mysql-server-5.0 and mysql-client-5.0
the status of zabbix-server is down
wht´s happend?
thanks
__________________
Rodrigo Pacheco
Linux Administrator.
Brazil - Sao Paulo
this and normal?
wht´s happend?
thanks
__________________
Rodrigo Pacheco
Brazil - Sao Paulo
