Hi i got zabbix 1.3.1 on my server and agent 1.1.4.1 on both the server and a test system for monitoring.
My disk space is showing 988kb free on root directory when it should be MB
and anything that's showing that should be say 3.2 GB is showing as 3.2 MB
I'm using Debian Etch.
I noticed however on the test system i originally had agent 1.3 installed on it somehow with the testing repository for zabbix. But when i tried to apt-get install zabbix-agent on the server with the same repository set it kept grabbing 1.1.4.1
So i ended up throwing 1.1.4.1 agent on both.
Problem has been the same in all setups with or without 1.3 agent.
Any help would be appreciated thanks.
