i will monitoring CPU Temp. I install sensord in ubuntu server.
Sensord is started.
sensors:
w83627ehf-isa-0290
Adapter: ISA adapter
Case Fan: 0 RPM (min = 1318 RPM, div = 128)
CPU Fan: 2445 RPM (min = 1704 RPM, div = 8)
fan3: 0 RPM (min = 60 RPM, div = 128)
fan4: 0 RPM (min = 0 RPM, div = 128)
Sys Temp: +47°C (high = +45°C, hyst = +40°C)
CPU Temp: +30.5°C (high = +45.0°C, hyst = +40.0°C)
temp3: +123.0°C (high = +80.0°C, hyst = +75.0°C)
in Zabbix i have this error:
Parameter [sensor[temp3]] is not supported by agent on host
Parameter [sensor[temp2]] is not supported by agent on host
Parameter [sensor[temp1]] is not supported by agent on host
Ideas???
Christian
Sensord is started.
sensors:
w83627ehf-isa-0290
Ideas???
Christian
