Zabbix 1.1.6 suddenly segfault
  • bbrendon
    • Sep 2005
    • 873
    How interesting. Any ideas how to fix this one?
    zabbix_server[5822]: segfault at 0000000000000000 rip 00002b6ef7f12929 rsp 00007fffb36af708 error 6
    server:/var/log/zabbix-server#
    015083:20070314:002946 End of update_triggers [20504]
    015083:20070314:002946 Sending back [OK
    015083:20070314:002946 Length [3]
    015083:20070314:002946 Sockfd [5]
    015083:20070314:002946 After write()
    015083:20070314:002946 Before accept()
    015084:20070314:002946 After accept()
    015084:20070314:002946 In process_trapper_child
    015084:20070314:002946 Before read(65000)
    015084:20070314:002946 Read 160 bytes
    015084:20070314:002946 After read() 3 [160]
    015084:20070314:002946 Got data:<req><host>c2VhYnVyeS5zYjE=</host><key>cGVyZl9jb3VudGVyW1xQaHlzaWNhbERpc2soX1RvdGFsKVxDdXJyZW50IERpc2sgUXVldWUgTGVuZ3RoXQ==</key><data>MS4wMDAwMDA=</data></req>
    015084:20070314:002946 Trapper got [<req><host>c2VhYnVyeS5zYjE=</host><key>cGVyZl9jb3VudGVyW1xQaHlzaWNhbERpc2soX1RvdGFsKVxDdXJyZW50IERpc2sgUXVldWUgTGVuZ3RoXQ==</key><data>MS4wMDAwMDA=</data></req>]
    015084:20070314:002946 XML received [<req><host>c2VhYnVyeS5zYjE=</host><key>cGVyZl9jb3VudGVyW1xQaHlzaWNhbERpc2soX1RvdGFsKVxDdXJyZW50IERpc2sgUXVldWUgTGVuZ3RoXQ==</key><data>MS4wMDAwMDA=</data></req>]
    015084:20070314:002946 In process_data([seabury.sb1],[perf_counter[\PhysicalDisk(_Total)\Current Disk Queue Length]],[1.000000],[])
    015084:20070314:002946 Executing query:select i.itemid,i.key_,h.host,h.port,i.delay,i.description,i.nextcheck,i.type,i.snmp_community,i.snmp_oid,h.useip,h.ip,i.history,i.lastvalue,i.prevvalue,i.hostid,h.status,i.value_type,h.errors_from,i.snmp_port,i.delta,i.prevorgvalue,i.lastclock,i.units,i.multiplier,i.snmpv3_securityname,i.snmpv3_securitylevel,i.snmpv3_authpassphrase,i.snmpv3_privpassphrase,i.formula,h.available,i.status,i.trapper_hosts,i.logtimefmt,i.valuemapid from hosts h, items i where h.status=0 and h.hostid=i.hostid and h.host='seabury.sb1' and i.key_='perf_counter[\\PhysicalDisk(_Total)\\Current Disk Queue Length]' and i.status=0 and i.type in (2,7)
    015084:20070314:002946 In check_security()
    015084:20070314:002946 Processing [1.000000]
    015084:20070314:002946 In process_new_value()
    015084:20070314:002946 In add_history(perf_counter[\PhysicalDisk(_Total)\Current Disk Queue Length],,0,2)
    015084:20070314:002946 In add_history(21363,DOUBLE:1.000000)
    015084:20070314:002946 In add_history()
    015084:20070314:002946 Executing query:insert into history (clock,itemid,value) values (1173857386,21363,1.000000)
    015078:20070314:002946 Executing query:select i.itemid,i.key_,h.host,h.port,i.delay,i.description,i.nextcheck,i.type,i.snmp_community,i.snmp_oid,h.useip,h.ip,i.history,i.lastvalue,i.prevvalue,i.hostid,h.status,i.value_type,h.errors_from,i.snmp_port,i.delta,i.prevorgvalue,i.lastclock,i.units,i.multiplier,i.snmpv3_securityname,i.snmpv3_securitylevel,i.snmpv3_authpassphrase,i.snmpv3_privpassphrase,i.formula,h.available,i.status,i.trapper_hosts,i.logtimefmt,i.valuemapid from hosts h, items i where i.nextcheck<=1173857386 and i.status in (0) and i.type not in (2,7) and h.status=0 and h.disable_until<=1173857386 and h.errors_from!=0 and h.hostid=i.hostid and i.key_ not in ('status','icmpping','icmppingsec','zabbix[log]') order by i.nextcheck
    015078:20070314:002946 Spent 0 seconds while updating values
    015078:20070314:002946 Executing query:select count(*),min(i.nextcheck) as nextcheck from items i,hosts h where i.nextcheck<=1173857386 and i.status in (0) and i.type not in (2,7) and h.status=0 and h.disable_until<=1173857386 and h.errors_from!=0 and h.hostid=i.hostid and i.key_ not in ('status','icmpping','icmppingsec','zabbix[log]') order by nextcheck
    015078:20070314:002946 No items to update for minnextcheck.
    015078:20070314:002946 Nextcheck:-1 Time:1173857386
    015078:20070314:002946 Sleeping for 5 seconds
    015079:20070314:002946 Timeout while executing operation.
    015074:20070314:002946 One server process died. Shutting down...
    015074:20070314:002946 0. Killing PID=[15075]
    015074:20070314:002946 1. Killing PID=[15076]
    015074:20070314:002946 2. Killing PID=[15077]
    015074:20070314:002946 3. Killing PID=[15078]
    015074:20070314:002946 4. Killing PID=[15079]
    015074:20070314:002946 5. Killing PID=[15080]
    015074:20070314:002946 6. Killing PID=[15081]
    015074:20070314:002946 7. Killing PID=[15082]
    015081:20070314:002946 Server [7]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    015075:20070314:002946 Server [1]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    015082:20070314:002946 Server [8]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    015077:20070314:002946 Server [3]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    015083:20070314:002946 Server [9]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    015078:20070314:002946 Server [4]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    015080:20070314:002946 Server [6]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    015074:20070314:002946 8. Killing PID=[15083]
    015074:20070314:002946 9. Killing PID=[15084]
    015084:20070314:002946 Server [10]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    015074:20070314:002946 ZABBIX server is down.
    015079:20070314:002946 Server [5]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    Unofficial Zabbix Expert
    Blog, Corporate Site
  • bbrendon
    • Sep 2005
    • 873
    I went back to a database backup that is about 1 month old and it fixed the problem.
    I'll have to figure this one out in the morning. At least for now the alerts are back online.
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Please can you grep for '15076' and post last few lines here.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • bbrendon
        • Sep 2005
        • 873
        You are so smart
        How did you know it was #1?
        It appears the remote actions are causing it to crash!
        020009:20070314:104035 Run remote commands START [actionid:36]
        020009:20070314:104035 get_next_command START [command_list: 'box#touch /tmp/remotecommandtest']
        020009:20070314:104035 Result of get_next_command [alias:box, is_group:1, command:touch /tmp/remotecommandtest]
        020009:20070314:104035 Executing query:select distinct h.host from hosts_groups hg,hosts h, groups g where hg.hostid=h.hostid and hg.groupid=g.groupid and g.name='box'
        020009:20070314:104035 run_remote_command START [hostname: 'box.cheetah3', command: 'touch /tmp/remotecommandtest']
        020009:20070314:104035 Executing query:select distinct host,ip,useip,port from hosts where host='box.cheetah3'
        020009:20070314:104035 get_value_agent: host[box.cheetah3] ip[] key [system.run[touch /tmp/remotecommandtest,nowait]]
        020009:20070314:104035 gethostbyname() failed [Unknown host]
        020009:20070314:104035 run_remote_command [result:-3]
        020009:20070314:104035 run_remote_command START [hostname: 'box.elephant', command: 'touch /tmp/remotecommandtest']
        020009:20070314:104035 Executing query:select distinct host,ip,useip,port from hosts where host='box.elephant'
        020009:20070314:104035 get_value_agent: host[box.elephant] ip[] key [system.run[touch /tmp/remotecommandtest,nowait]]
        020009:20070314:104035 run_remote_command START [hostname: 'box.firewall', command: 'touch /tmp/remotecommandtest']
        020009:20070314:104035 Executing query:select distinct host,ip,useip,port from hosts where host='box.firewall'
        020009:20070314:104035 get_value_agent: host[box.firewall] ip[67.155.108.2] key [system.run[touch /tmp/remotecommandtest,nowait]]
        020007:20070314:104040 1. Killing PID=[20009]
