Cannot create PID file
  • mg3
    • Mar 2007
    • 9
    after a restart of the server, the zabbix server cannot be started again. I checked the logfile:
    005512:20070319:222449 Cannot create PID file [/var/run/zabbix-server/zabbix_server.pid] [No such file or directory]
    I have no idea why the pid file can't be created anymore
    Anyone?
    Thanks,
    Jo
  • James Wells
    • Jun 2005
    • 664
    Greetings,
    Right off the bat, I suspect you are missing the directory /var/run/zabbix-server By default the pid file is /var/run/zabbix-server.pid, so the start stop script may have removed the directory instead of the pid file.
    Unofficial Zabbix Developer
    • mg3
      • Mar 2007
      • 9
      I created the directory again but it said 'permission denied' in the logfile. So I reinstalled the server and now the problem is solved, but I am affraid when the server restarts, the problem will rise again..
      greetz,
      Jo
      • tronite
        • Jun 2007
        • 147
        Anyone?
        Thanks,
        Jo
        Hey this reminds me of a similar incident where there I could not stop the zabbix server and alas how I hacked this was by rm -f the zabbix pid file then start the service again, brings me to wonder but it's probably a problem between the keyboard and the screen.
        • psmith
          • May 2007
          Perhaps the user that Zabbix is running under does not have appropriate permissions to delete in /var ?
          • niak
            • Nov 2007
            • 30
            cannot create pid file
            I have the same problem,
            When i installed zabbix (1.4.1) for the first time, i have no problem :i can monitor my hosts, create graphs...
            But when i restart my system, zabbix delete the directory : zabbix-server in /var/run.
            In the zabbix_server.log :"cannot create PID file [/var/run/zabbix-server/zabbix_server.pid]
            So i can't restart my server after install .
            Any one have solutions ?
            I am on ubuntu 7.10 !
            sorry for my English, i'm French
            • niak
              • Nov 2007
              • 30
              Hi ,
              I find the solution of my problem:
              /etc/zabbix/zabbix-server.conf : It is necessary to change : PidFile=/var/run/zabbix-server/zabbix_server.pid in
              PidFile=/home/your_account_name/zabbix/zabbix_server.pid
              You have to create a directory "zabbix" in your home, don't create the file "zabbix_server.pid" in the directory manually! the system will create the file after restarting!
              Restart your system! and the problem disappears ! No errors in zabbix-server.log
              PS(I am on Ubuntu 7.10)
              Bye...
              • nlp
                • Oct 2008
                Did not help for me
                Hey,
                I still have this problem... For me its looks like zabbix-server isnt running under the user zabbix
                • tof233
                  • Nov 2010
                  • 94
                  Fixed by setting in zabbix_agentd.conf : PidFile=/var/run/zabbix/zabbix_agentd.pid
                  (and for Zabbix server: PidFile=/var/run/zabbix/zabbix_server.pid )
                  and doing:
                  shell > chown -R zabbix:zabbix /var/run/zabbix
                  • alp
                    • Nov 2009
                    • 90
                    I have a same problem in gentoo now.
                    When i chown /var/run/zabbix and reboot system, after that this directory is removed =( And zabbix don't start. How can i solve it without copy PID to my home dir?
                    • Skymit
                      • Sep 2020
                      mkdir /var/run/zabbix
                      chown zabbix:zabbix /var/run/zabbix
                      systemctl restart zabbix-java-gateway.service
                      • KillingerJose
                        • Oct 2020
                        Thanks for the update and quick reply. I'll be sure to keep an eye on this thread.
                        walgreenslistens
                        • Michaell
                          • Oct 2020
                          In fact, this file was simply not there, we create a folder, a file and assign rights GarageBand App
                          HTML Code:
                          mkdir /var/run/zabbix touch /var/run/zabbix/zabbix_agentd.pid chown -R zabbix:zabbix /var/run/zabbix chmod -R [COLOR=var(--hljs-number)]775[/COLOR] /var/run/zabbix
