web frontend timeout
  • Villain
    • Aug 2006
    • 84
    Is there a way to change the timeout used for the web frontend? It seems to have a 5 minute or less timeout before it auto-logs me out. As I am configuring servers to work with this, that's not enough time to bounce back and forth and make sure that I'm doing something.
    If there's a way to change this, please let me know.
    Thanks,
    -Villain
  • James Wells
    • Jun 2005
    • 664
    Greetings,
    Certainly. Once you are logged in there is a link on the far right, at the top called Profile. You can go in there and change your autologout time, which is set to 300 seconds IIRC. Or, as admin, you can go to the users page, select the user and adjust the autologout time there as well.
    Unofficial Zabbix Developer
    • Villain
      • Aug 2006
      • 84
      I shall flog myself for overlooking this little 'feature' >.>
      Thanks James!
      • tronite
        • Jun 2007
        • 147
        Thanks,
        -Villain
        Atleast you get a time-out some of us get nothing at all.
