Remote Commands (yet again!)
  • bbrendon
    • Sep 2005
    • 873
    Okay, I see some people have magically gotten this to work.
    As you can see below, the basic command executes according to the server, but that file doesn't exist. I even double checked permissions on /tmp.
    029667:20070324:165954 Run remote commands START [actionid:34]
    029667:20070324:165954 run_remote_command START [hostname: 'company.server', command: 'touch /tmp/asdf']
    029667:20070324:165954 run_remote_command [result:-3]
    029667:20070324:165954 Run remote commands END
    Could this have something to do with the fact that I ONLY use active checks?
    My next option is to write a cron job against the database. I looked into this, but I can't figure out how to detect a trigger based on severity level and host group. It appears I have to decode the expression row column in the triggers table.
    AhhhhH!
    Unofficial Zabbix Expert
    Blog, Corporate Site
  • bbrendon
    • Sep 2005
    • 873
    Wow. Ok, so this is now a FEATURE request and notice to everyone else.
    REMOTE COMMANDS REQUIRE THE ZABBIX SERVER TO CONTACT THE AGENT.
    So if your agents are behind a firewall, then you're SOL. Also, if you can't telnet to port 10050 of the hostname or IP as configured in the Zabbix server hosts, it will not work.
    Improperly configured Remote Commands can segfault your zabbix server, so tread carefully and test.
    • bbrendon
      • Sep 2005
      • 873
      One finaly note, you want a result code of "-2" in the zabbix server logs which I guess means success.
      Good:
      029666:20070324:170951 run_remote_command [result:-2]
      Bad:
      029666:20070324:170951 run_remote_command [result:-3]
      • Niels
        • May 2007
        • 239
        Has this been fixed? The newest manual doesn't mention it.
        • spetznaz
          • May 2008
          Have you Enabled Remote Commands in zabbix agent conf ???
          # Enable remote commands for ZABBIX agent. By default remote commands disabled.
          EnableRemoteCommands=1
          • Niels
            • May 2007
            • 239
            @spetznaz: The issue here is active / inactive, not enabled / disabled.
            • stanko12
              • Nov 2011
              Remote command Active host
              so is this changed or not? can remote command be used with active host behind a firewall? I've been trying to get this to work for days now but it does not and i get that
              "End run_remote_command(result:-3)"
              i fixed sudoers and have remote commands enabled (set to 1) in conf file
              • nelsonab
                • Sep 2006
                • 1233
                Remote commands are *NOT* related to items and their configuration be it active or passive. Remote commands require that the Zabbix Server process be able to connect with the agent (in a manner similar to passive items, but it's still not the same). If the Server can connect with the agent and the appropriate configuration entry "EnableRemoteCommands" has been enabled then remote commands will work. If they aren't check the log file on the agent.
                Thus if you cannot communicate from the server to the agent, remote commands don't work.
                RHCE, author of zbxapi
                • stanko12
                  • Nov 2011
                  by active host i mean a host that is behind a firewall and uses active checks to communicate with server so the server does note have it's ip.
                  this is addressed here:
                  so i guess my answer is NO that remote command will not work in my case
                  • nelsonab
                    • Sep 2006
                    • 1233
                    That is correct. If the server cannot connect to the agent you cannot user remote commands at this time. If something like AQMP were implemented then concepts like active/passive would become moot and it would then be possible in your environment. But AQMP and Zabbix is just a dream right now. :-)
                    • stanko12
                      • Nov 2011
                      well if actions could activate and deactivate items all would be solved.
                      item with system.run
                      event (ftp down) trigers action which activates item which sends a command which changes state (ftp up) which trigers action to deactivate item.
                      • nelsonab
                        • Sep 2006
                        • 1233
                        You can enable/disable items right now, but you will need to do a little programming to make it happen. Write an external script which takes an item name as the parameter. Tie that script to an action and subsequently a trigger. When a trigger activates, and the script get's called you can have that script use the API to enable/disable items as you need to. Is it pretty, no, but can you do what you want now, yes.
                        • stanko12
                          • Nov 2011
                          so i have solved it without script.
                          Client -Zabbix agentd active mode behind a firewall
                          Server - has also zabbix agentd running but in passive mode
                          so on my client sshd goes down, an Item collects that data and rises a trigger which invokes an action that executes a remote command on the Zabbix server where this command (sql command directly into database)changes the status of my "Custom Item" to active. My custom item using system.run puts a command to restart sshd in the data which zabbix_agentd collects. next time it collects data it gets the command to restart sshd. Once sshd is restarted Item collects that data which rises another trigger which starts another action which sets the status of my "Custom Item" to disabled.
