compile trouble in 1.1.6 with-static
  • amcorreia
    • Mar 2006
    • 73
    Hi
    I'am tring to compile zabbix server statically.
    I do:
    ./configure --enable-server --enable-agent --with-pgsql --enable-static
    and get this error.. (a little snipt of errors)
    /usr/lib/libpq.a(fe-auth.o)(.text+0x18d): In function `pg_krb5_init':
    : undefined reference to `krb5_cc_close'
    /usr/lib/libpq.a(fe-auth.o)(.text+0x19b): In function `pg_krb5_init':
    : undefined reference to `krb5_free_context'
    I have the follow packages installed.
    epyon:~# dpkg -l | grep postgresql
    ii postgresql 7.4.7-6sarge4 object-relational SQL database management sy
    ii postgresql-cli 7.4.7-6sarge4 front-end programs for PostgreSQL
    ii postgresql-con 7.4.7-6sarge4 additional facilities for PostgreSQL
    ii postgresql-dev 7.4.7-6sarge4 development files for libpq (PostgreSQL libr
    epyon:~# dpkg -l | grep kr
    ii libkrb-1-kerbe 1.2.2-11.2 Kerberos Libraries for Kerberos4 From KTH
    ii libkrb5-17-hei 0.6.3-10sarge2 Libraries for Heimdal Kerberos
    ii libkrb5-dev 1.3.6-2sarge3 Headers and development libraries for MIT Ke
    ii libkrb53 1.3.6-2sarge3 MIT Kerberos runtime libraries
    ii libsasl2-krb4- 2.1.19-1.1 Kerberos4 module for SASL using MIT Kerbero
    epyon:~# dpkg -l | grep ssl
    ii libssl-dev 0.9.7e-3sarge4 SSL development libraries, header files and
    rc libssl0.9.6 0.9.6m-1sarge4 SSL shared libraries (old version)
    ii libssl0.9.7 0.9.7e-3sarge4 SSL shared libraries
    ii openssl 0.9.7e-3sarge4 Secure Socket Layer (SSL) binary and related
    ii ssl-cert 1.0-11 Simple debconf wrapper for openssl
    ii ssldump 0.9b3-2 An SSLv3/TLS network protocol analyzer
