All of a sudden the zabbix_server process shuts down right after I start it. This is what I find in the log.
I have really no clue at what's wrong. It worked perfectly for a week until I noticed that data wan't updated on the gui.
Thanks.
003544:20070328:065208 Starting zabbix_server. ZABBIX 1.1.6.
003544:20070328:065208 Executing query:select refresh_unsupported from config
003544:20070328:065208 In DBupdate_triggers_after_restart()
<SNIP> SQL QUERY TEXT?
003553:20070328:065211 In child_main()
003553:20070328:065211 server #6 started [Trapper]
003553:20070328:065211 Before DBconnect()
003549:20070328:065211 server #3 started [ICMP pinger]
003549:20070328:065211 In create_host_file()
003549:20070328:065211 Executing query:select distinct h.ip from hosts h,items i where i.hostid=h.hostid and (h.status=0 or (h
.status=0 and h.available=2 and h.disable_until<=1175057531)) and (i.key_='icmpping' or i.key_='icmppingsec') and i.type=3 and
i.status=0 and h.useip=1
003549:20070328:065211 Executing query:select distinct h.host from hosts h,items i where i.hostid=h.hostid and (h.status=0 or
(h.status=0 and h.available=2 and h.disable_until<=1175057531)) and (i.key_='icmpping' or i.key_='icmppingsec') and i.type=3 a
nd i.status=0 and h.useip=0
003549:20070328:065211 In do_ping()
003553:20070328:065211 After DBconnect()
003553:20070328:065211 Before accept()
003555:20070328:065211 In child_main()
003555:20070328:065211 server #7 started [Trapper]
003555:20070328:065211 Before DBconnect()
003555:20070328:065211 After DBconnect()
003555:20070328:065211 Before accept()
003556:20070328:065211 In child_main()
003556:20070328:065211 server #8 started [Trapper]
003556:20070328:065211 Before DBconnect()
003556:20070328:065211 After DBconnect()
003556:20070328:065211 Before accept()
003563:20070328:065211 In child_main()
003563:20070328:065211 server #9 started [Trapper]
003563:20070328:065211 Before DBconnect()
003563:20070328:065211 After DBconnect()
003563:20070328:065211 Before accept()
003544:20070328:065211 server #0 started [Housekeeper]
003544:20070328:065211 0. PID=[3546]
003544:20070328:065211 1. PID=[3548]
003544:20070328:065211 2. PID=[3549]
003544:20070328:065211 3. PID=[3551]
003544:20070328:065211 4. PID=[3552]
003544:20070328:065211 5. PID=[3553]
003544:20070328:065211 6. PID=[3555]
003544:20070328:065211 7. PID=[3556]
003544:20070328:065211 8. PID=[3563]
003544:20070328:065211 9. PID=[3565]
003551:20070328:065211 server #4 started [Poller for unreachable hosts. SNMP:ON]
003551:20070328:065211 Executing query:select i.itemid,i.key_,h.host,h.port,i.delay,i.descriptio n,i.nextcheck,i.type,i.snmp_co
mmunity,i.snmp_oid,h.useip,h.ip,i.history,i.lastva lue,i.prevvalue,i.hostid,h.status,i.value_type,h.e rrors_from,i.snmp_port,i.d
elta,i.prevorgvalue,i.lastclock,i.units,i.multipli er,i.snmpv3_securityname,i.snmpv3_securitylevel,i. snmpv3_authpassphrase,i.sn
mpv3_privpassphrase,i.formula,h.available,i.status ,i.trapper_hosts,i.logtimefmt,i.valuemapid from hosts h, items i where i.nex
tcheck<=1175057531 and i.status in (0) and i.type not in (2,7) and h.status=0 and h.disable_until<=1175057531 and h.errors_fro
m!=0 and h.hostid=i.hostid and i.key_ not in ('status','icmpping','icmppingsec','zabbix[log]') order by i.nextcheck
003551:20070328:065211 GOT VALUE TYPE [0x0]
003551:20070328:065211 get_value_agent: host[**] ip[] key [vfs.file.size[c:\msdos.sys]]
003552:20070328:065211 server #5 started [Poller. SNMP:ON]
003552:20070328:065211 Executing query:select i.itemid,i.key_,h.host,h.port,i.delay,i.descriptio n,i.nextcheck,i.type,i.snmp_co
tcheck<=1175057531 and i.status in (0,3) and i.type not in (2,7) and h.status=0 and h.disable_until<=1175057531 and h.errors_f
rom=0 and h.hostid=i.hostid and mod(i.itemid,1)=0 and i.key_ not in ('status','icmpping','icmppingsec','zabbix[log]') order by
i.nextcheck
003552:20070328:065211 GOT VALUE TYPE [0x0]
003552:20070328:065211 get_value_agent: host[**] ip[**] key [agent.version]
003552:20070328:065211 Sending [agent.version
003552:20070328:065211 RESULT_STR [Ü]
003552:20070328:065211 In process_new_value()
003552:20070328:065211 In add_history(agent.version,,2,4)
003552:20070328:065211 In add_history(17752,STRING:1.1.6)
003552:20070328:065211 In add_history_log()
003565:20070328:065211 In child_main()
003565:20070328:065211 server #10 started [Trapper]
003565:20070328:065211 Before DBconnect()
003565:20070328:065211 After DBconnect()
003565:20070328:065211 Before accept()
003544:20070328:065211 One server process died. Shutting down...
003546:20070328:065211 Server [1]. Got QUIT or INT or TERM or PIPE signal. Exiting...
003544:20070328:065211 0. Killing PID=[3546]
003548:20070328:065211 Server [2]. Got QUIT or INT or TERM or PIPE signal. Exiting...
003544:20070328:065211 1. Killing PID=[3548]
003549:20070328:065211 Server [3]. Got QUIT or INT or TERM or PIPE signal. Exiting...
003544:20070328:065211 2. Killing PID=[3549]
003544:20070328:065211 3. Killing PID=[3551]
003544:20070328:065212 4. Killing PID=[3552]
003553:20070328:065212 Server [6]. Got QUIT or INT or TERM or PIPE signal. Exiting...
003544:20070328:065212 5. Killing PID=[3553]
003555:20070328:065212 Server [7]. Got QUIT or INT or TERM or PIPE signal. Exiting...
003544:20070328:065212 6. Killing PID=[3555]
003556:20070328:065212 Server [8]. Got QUIT or INT or TERM or PIPE signal. Exiting...
003544:20070328:065212 7. Killing PID=[3556]
003563:20070328:065212 Server [9]. Got QUIT or INT or TERM or PIPE signal. Exiting...
003544:20070328:065212 8. Killing PID=[3563]
003551:20070328:065212 Server [4]. Got QUIT or INT or TERM or PIPE signal. Exiting...
003565:20070328:065212 Server [10]. Got QUIT or INT or TERM or PIPE signal. Exiting...
003544:20070328:065212 9. Killing PID=[3565]
003544:20070328:065212 ZABBIX server is down.
i.nextcheck
Thanks.
