Hello.
I'm testing zabbix 1.3.4 with postgresql 8.2.3 and php-pgsql-4.4.5.
Installation was successful except issue with php and bcmath (http://www.zabbix.com/forum/showthread.php?t=5619). But now I have strange problem. When I add new host to monitor (localhost in my case), things work fine for about a minute, and then something breakes. Messages like:
starts flooding zabbix_server.log
Restarting of zabbix_server doesn't help - it continues flooding after restart
Although I'm not familiar with php, I've found some similar code in include/db.inc.php file of GUI.
Seems that values are not calculated by higlited expressions
The most strange thing that it works in the beginning (for about a minute or less), as i can see on graphs - there are short lines there representing some data. You can see example image, attached. Do anybody have any suggestions about this issue?
16648:20070328:135347 Query::insert into ids (nodeid,table_name,field_name,nextid) values (0,'events'
,'eventid',)
16648:20070328:135347 Query failed:PGRES_FATAL_ERROR:ERROR: syntax error at or near ")"
LINE 1: ...table_name,field_name,nextid) values (0,'events','eventid',)
function get_dbid($table,$field)
global $ZBX_CURNODEID;
if(!isset($ZBX_CURNODEID)) init_nodes();
/* $row=DBfetch(DBselect("select max($field) as id from $table where ".DBid2nodeid($field)." in (".$ZBX_CURNODEID.")"));
if($row && !is_null($row["id"]))
return bcadd($row["id"],1);
else
return bcadd(bcmul($ZBX_CURNODEID,"100000000000000"),1);
$found = false;
do
$row = DBfetch(DBselect("select nextid from ids where nodeid=$ZBX_CURNODEID and table_name='$table' and field_name='$field'"));
if(!$row || is_null($row["nextid"]))
if(!$row || is_null($row["id"]))
[COLOR=Red] DBexecute("insert into ids (nodeid,table_name,field_name,nextid) values ($ZBX_CURNODEID,'$table','$field',".bcadd(bcmul($ZBX_CURNODEID,"100000000000000"),1).")");[/COLOR]
else
[COLOR=Red]DBexecute("insert into ids (nodeid,table_name,field_name,nextid) values ($ZBX_CURNODEID,'$table','$field',".$row["id"].")");[/COLOR]
continue;
else
$ret1 = $row["nextid"];
DBexecute("update ids set nextid=nextid+1 where nodeid=$ZBX_CURNODEID and table_name='$table' and field_name='$field'");
/* Should never be here */
continue;
else
$ret2 = $row["nextid"];
if(bccomp(bcadd($ret1,1),$ret2) ==0)
$found = true;
while(false == $found);
return $ret2;
