No graphs in Zabbix 1.4
  • skione
    • Mar 2007
    I am a relatively new user to linux/zabbix but so far I got the app installed and running and I got a few devices being monitored.
    The problem I am having now is no graphs.
    I click create graph and none show up. I am sure I am missing a library or need to edit a config but I am unsure what to do.
    Please help.
  • predatorz
    • Mar 2007
    • 109
    Install gd-devel
    Hope it helps
    • skione
      • Mar 2007
      I appreciate your response but I can not find gd-devil in any of the repos.
      I even tried to google it and found no reference to it.
      What is the exact package name?
      Is there a complete list of all packages required?
      The documentation seems very incomplete in that area.
      EDIT:
      I see I made a typo and spelled it devil instead of devel. This appears to be a Redhat SuSe thing. I am using Unbuntu. Do you know the equivalent or do I have to try and convert the rpm?
      EDIT2:
      Ok the library is libgd2 and I had it installed. I did have an image problem and that made it work. I think this is more of a db issue. I am trying to install a mysql library that may do the trick.
      FINAL EDIT:
      Well no dice. I go into configuration then graphs, create a graph it says graph added but does not show in the list.
      • steftheo
        • Feb 2007
        • 11
        Graph on monitoring
        Hi there!
        Do you make this graphs on a template or it is a stand alone graph?
        check the group tab on the right and select all search for the graph you just create and i believe you will find it somewere there.
        hope that helps!
