zabbixw32 causes 100% cpu
  • mrmike136
    • Mar 2005
    I have the agent running just fine on several other machines but on one everytime I start the service zabbixw32.exe will utilize 100% of the cpu.
    Any ideas?
  • cooper
    • Sep 2004
    • 110
    might be something in you config file. Could you post agentd.conf? Also zabbix_agentd.log would be helpful.
    cooper
    • mrmike136
      • Mar 2005
      here is the config. It is just standard stuff I only changed the server ip and port. Does windows create a log file somewhere or just use the event log? I did see one anywhere.
      # This is config file for zabbix_agentd
      # To get more information about Zabbix, go http://zabbix.sourceforge.net
      # IP address of Zabbix server. No spaces allowed.
      Server=192.168.50.8
      # Listen port. Default is 10000
      ListenPort=20000
      # IP address to bind agent
      # If missing, bind to all available IPs
      #ListenIP=192.168.50.55
      # Number of pre-forked instances of zabbix_agentd.
      # Default value is 5
      # This parameter must be between 1 and 16
      StartAgents=5
      # Specifies debug level
      # 0 - debug is not created
      # 1 - critical information
      # 2 - error information
      # 3 - warnings (default)
      # 4 - for debugging (produces lots of information)
      DebugLevel=3
      # Name of PID file
      PidFile=/var/tmp/zabbix_agentd.pid
      # Name of log file.
      # If not set, syslog will be used
      LogFile=/tmp/zabbix_agentd.log
      # Spend no more than Timeout seconds on processing
      # Must be between 1 and 30
      Timeout=3
      ##### Experimental options. Use with care ! #####
      # Get rid of sockets in TIME_WAIT state
      # This will set socket option SO_LINGER
      # NoTimeWait=1
      ##### End of experimental options
      # Format: UserParameter=<key>,<shell command>
      # Note that shell command should return numeric value
      #UserParameter=system[test],who|wc -l
      ### Set of parameter for monitoring MySQL server (v3.23.42 and later)
      ### Change -u<username> and add -p<password> if required
      #UserParameter=mysql[ping],mysqladmin -uroot ping|grep alive|wc -l
      #UserParameter=mysql[uptime],mysqladmin -uroot status|cut -f2 -d":"|cut -f1 -d"T"
      #UserParameter=mysql[threads],mysqladmin -uroot status|cut -f3 -d":"|cut -f1 -d"Q"
      #UserParameter=mysql[questions],mysqladmin -uroot status|cut -f4 -d":"|cut -f1 -d"S"
      #UserParameter=mysql[slowqueries],mysqladmin -uroot status|cut -f5 -d":"|cut -f1 -d"O"
      #UserParameter=mysql[qps],mysqladmin -uroot status|cut -f9 -d":"
      #UserParameter=version[mysql],mysql -V
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        It was already discussed somewhere else. This is Windows bug.
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
        • mrmike136
          • Mar 2005
          I figured was just hoping to get some direction to what the problem is. Any idea where the thread this was discussed is at? I have done several searches and can't seem to find anything.
