Active agents stop sending data (1.1.6)
  • glut0r
    • Mar 2007
    • 38
    #16
    ah nice one I got here,
    026507:20070505:121137 Error gethostbyname, can not resolve [zabbix...pl]
    026507:20070505:121139 Connection from [87...] rejected. Allowed server is [zabbix...pl,zabbix-2...pl,localhost]
    026508:20070505:153330 gethostbyname() failed [Host name lookup failure]
    026508:20070505:153330 Getting list of active checks failed. Will retry after 60 seconds
    026505:20070507:163913 Error gethostbyname, can not resolve [zabbix...pl]
    026504:20070507:163921 Error gethostbyname, can not resolve [zabbix...pl]
    026505:20070507:163921 Connection from [87...] rejected. Allowed server is [zabbix...pl,zabbix-2...pl,localhost]
    026504:20070507:163921 Connection from [87...] rejected. Allowed server is [zabbix...pl,zabbix-2...pl,localhost]
    026507:20070507:185246 Error gethostbyname, can not resolve [zabbix...pl]
    026507:20070507:185301 Connection from [87...] rejected. Allowed server is [zabbix...pl,zabbix-2...pl,localhost]
    then there's only grey appearing in monitoring overview.
    so, my suspection is, that when dns dies, zabbix agent cannot resolve server, and somehow it dies.
    Seems repeatable. No dns or high latency, and agent hangs. Can anyone confirm ?
    HELP! Alexiej where are you! Hear us calling from the depths!
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      #17
      It is so obvious that ZABBIX is unable to determine IP adress by DNS name if DNS server is down. Does it require further explanation?
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • glut0r
        • Mar 2007
        • 38
        #18
        Of course it does, why it did't come back after dns was restored?
        Routers flaps from time to time. Agents have to return withouth restarting them.
        • glut0r
          • Mar 2007
          • 38
          #19
          Captain's log, star date 1234
          Added static entry to /etc/hosts, now the only entry that is appearing in agent's log before it stops sending data to server is this:
          019917:20070511:152436 Error in connect() [zabbix....:10051] [Connectio
          n timed out]
          I found out that what causes this is routing loops and packet loss above, say 20%. Agent hangs then. There's something wrong with errors handling imho.
          • cpicton
            • Nov 2006
            • 35
            #20
            I am experiencing the same problem with active agents on 1.4
            The agent sometimes hangs when trying to send data during a network outage.
            When the network connectivity is restored, the agent stays in the hung state. Only restarting the agent fixes this. The agent *should* resume sending once the network is restored. I am sending to an IP address, not a hostname, so DNS is not the problem.
            I am currently running with debuglevel=5 to try get some logs of when this happens
            Once I have the logs I will post them here
            • bbrendon
              • Sep 2005
              • 873
              #21
              What ever happened with this?
              I just had a 1.1.6 agent on Windows require a restart.
              In the agent log is says:
              [09-Aug-2007 11:27:07] Active checks [Error in connect()]
              The last information in the zabbix database for the host had a time of 11:30
              Once the agent was restarted, everything was fine and dandy.
              Unofficial Zabbix Expert
              Blog, Corporate Site
              • [cc]smart
                • May 2005
                • 25
                #22
                Can see the effect with ZABBIX Agent (daemon) v1.4.2 (20 August 2007) server ZABBIX 1.4.2 .In my case it's annoying due to the need to use active checks (natted one way connection). Once clients using dynamic IP change that IP they stop sending data. (that IP is an external IP the clients don't know at all about, but a network interruption is involved due to that.)
                • Niels
                  • May 2007
                  • 239
                  #23
                  I have this problem too. I have two remote machines: A (Win 2003 Small Business) and B (Win 2003 Enterprise). They are on separate locations, and have different loads and configurations. However, the agent on A has never stopped sending data, while the one on B has done so several times. Both agents are 1.4.2, and all items are Active Agent. There are no hints in the log on B as to what's going on.
                  • steria
                    • Jun 2007
                    • 17
                    #24
                    Same problem here!
                    Yesterday, I had to reboot my zabbix server (1.4.2) and since that, all client data collection is stopped (configured in check active).
                    Is there a solution for that problem? Don't tell me that I have to restart agent on all my clients (about 150)....
                    Thank you.
                    • bgerhardt
                      • Jun 2007
                      Never ending story
                      I started using zabbix over the summer and have had the same problem in both 1.1, 1.4, 1.4.1, ... 95% of my 100+ linux hosts are natted in remote locations where I may or may not have physical and/or ssh access. In the avg. week several of the hosts will hang and never recover without restart.
                      The feeling I had for a long time was that zabbix doesn't handle a half closed socket properly.
                      • richlv
                        • Oct 2005
                        • 3112
                        #26
                        see revisions 5150, 5152 and 5153 for stable branch and rev 5155 for trunk.
                        r5153 | sasha | 2007-12-10 17:26:32 +0200 (Mon, 10 Dec 2007) | 2 lines
                        - [ZBX-192] Data collection stopped after connection loss
                        • Niels
                          • May 2007
                          • 239
                          #27
                          OK, my bad: The bug is marked as resolved, but there's no explanation or revision reference in the bugtracker.
                          Ah!: In the bug tracker, the comments area can also show "all" and "change history".
                          • richlv
                            • Oct 2005
                            • 3112
                            #28
                            well, yes, adding message with revision would be helpful (other projects have this automated where adding BUG keyword in svn message automatically adds message to the bug and closes the bug).
                            • richlv
                              • Oct 2005
                              • 3112
                              #29
                              btw, i've seen some reports get nice svn commit information with log message and changed files, so it should be easier to track issues.
                              though it probably depends on developers using the feature in all cases
                              • pasqu
                                • Jun 2007
                                • 29
                                #30
                                I have this issue also with 1.8.4 version.
                                I see that clock change (with ntpdate for example) lock the agent active check.
