nextcheck = 0
  • steff
    • Jul 2006
    • 19
    nextcheck = 0
    Hi all,
    I'm having a very strange problem ... my zabbix server stops to
    perform items check (passive agent) because the nextcheck field
    of the items being involved is set to 0 (which in epoch time correspond
    to 1 Jan 1970). So the server doesn't check those hosts because
    the time for the check won't came.
    I don't know if this is a problem of my configuration (of the db , maybe?)
    or if it is a server process bug.
    Searching in this forum I've already found the same issue not solved on
    previous versions. If anybody is able to help it will be greatly appreciated,
    many thanks
    steff
    zabbix_server v. 1.1.4-1 from http://mirror.opf.slu.cz/zabbix on debian sarge system
    p.s.
    If I telnet to agent's port they reply me. For example at the command
    "agent.ping" I receive "1", so the agents work: great!, I have a monitoring
    server that do not monitor (how is it possible ?!?!?).
  • Arnas
    • May 2007
    We have same problem. Zabbix_server v 1.1.7
    Workaround is to manually update lastcheck and nextcheck values in DB to have correct timestamps.
    Alexei maybe you could explain why it is happening?
