syntax problem with system.run[] parameter
  • mardux
    • May 2007
    • 9
    hello everybody.
    i have test the system.run[] parameter on the client to monitoring, a suse linux 2.6, and i have a problem with the synax:
    gpvm01:/usr/local/bin # ./zabbix_agentd -t system.run[ls /]
    [m|ZBX_NOTSUPPORTED]
    gpvm01:/usr/local/bin # ./zabbix_agentd -t system.run[ls]
    system.run[ls] [t|zabbix_agent
    zabbix_agentd
    zabbix_get
    zabbix_sender]
    gpvm01:/usr/local/bin # ./zabbix_agentd -t system.run[ls -l]
    ./zabbix_agentd: invalid option -- l
    ./zabbix_agentd: invalid option -- ]
    usage: ./zabbix_agentd [-vhp] [-c <file>] [-t <metric>]
    when use an option for the command, zabbix_agentd report this error:
    or
    it didn't understand the space.
    How can i resolve?
    tnks
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    ./zabbix_agentd -t "system.run[ls -l]"
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • mardux
      • May 2007
      • 9
      thanks!
      now it works.
      another questions:
      i'm configure the system.run[] parameter with the text format data into the mysql db, but this type of field is too small for the result of the command, and a part of data is cut.
      can i modify this table and increase the dimensions of the field??
      wath is the table and the field for the parameter data?
      thanks very much
