Logfile: GetComputerName failed: what is it ?
  • mightor
    • May 2007
    • 15
    I am a new Zabbix user. In fact, I'm testing Zabbix through the OpenESM VMWare appliance. After spending a lot of time making the linux server and windows agent to communicate (zabbix server was simply not started :-)), I can now begin to collect data. But I have some error message in the logfile I cannot understand. Can someone please help me ?
    [15-May-2007 07:10:56] *************** Log file opened ****************
    [15-May-2007 07:10:56] GetComputerName failed: AddAlias == OK
    [15-May-2007 07:10:56] GetComputerName failed: CollectorThread start
    [15-May-2007 07:10:56] GetComputerName failed: counterPath1
    [15-May-2007 07:10:56] GetComputerName failed: \Processeur(_Total)\% Temps processeur
    [15-May-2007 07:10:56] GetComputerName failed: counterPath2
    [15-May-2007 07:10:56] GetComputerName failed: \Processeur(0)\% Temps processeur
    [15-May-2007 07:10:56] GetComputerName failed: counterPath3
    [15-May-2007 07:10:56] GetComputerName failed: \Système\Longueur de la file du processeur
    [15-May-2007 07:10:56] Collector thread initialized successfully
    [15-May-2007 07:10:56] Zabbix Win32 Agent started
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Is your computer name 15 characters long? If so, you hit a bug in ZABBIX Windows agent. It has been fixed for 1.3.x, not sure if the fix was intergrated into the latest 1.1.x.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • mightor
      • May 2007
      • 15
      Thank you for your prompt answer.
      I was running version 1.1 beta7-debug of the windows agent, provided in an auto-installable package by openESM.
      I've just installed the latest 1.1 (5 june 2006) and everything is OK for now.
      What about OpenESM ? Do you know this distribution of Zabbix software ? Do you agree with that ?
      Again, thank you for your help.
      Regards,
      Regis
      • mightor
        • May 2007
        • 15
        Just to complete: I can't find pre-compiled version 1.3.x on the web site. Is it only available as source code ?
        • mightor
          • May 2007
          • 15
          I answered too fast.
          In fact, there is no more error message, but with the new version (1.1 final) of windows agentd, no more data is received and the server log file shows:
          Parameter [diskfree[c:\]] is not supported by agent on host ...
          Revert to 1.1 beta 7, everything seems to work properly (data is received), except that the error message is back.
          - Does this error have an impact in Zabbix ?
          - Do I need to use the same version for server and agent ? How can I get the version number of my zabbix installation ?
          Thanks and regards,
          Regis
          • Rudolf
            • Dec 2004
            • 90
            Check the doc on http://www.zabbix.com/manual/v1.1/co...tems_agent.php
            I use the key vfs.fs.size[c:,free]
