syntax problem with system.run[] Trigger
  • mardux
    • May 2007
    • 9
    hi to all.
    Now i'm a problem with the syntax of a system.run trigger
    this is the parameter:
    system.run[ps -ef|grep esafe|grep -v zabbix|wc -l]
    the result of the command is 3.
    and this is the trigger:
    {ESAFE:system.run[ps -ef|grep esafe|grep -v zabbix|wc -l].last(0)}#3
    but the answer of zabbix is:
    Expression [{ESAFE:system.run[ps -ef|grep esafe|grep -v zabbix|wc -l].last(0)}] does not match to [server:key.func(param)]
    can i resolve without upgrade?
    now i working with the 1.1.6 release
    tnks
  • James Wells
    • Jun 2005
    • 664
    Greetings,
    Right off the bat, it looks like you are failing because of the item key length. Using un-modified Zabbix 1.1.x, you are limited to 40 characters in the item key length.
    Unofficial Zabbix Developer
    • mardux
      • May 2007
      • 9
      hello to all.
      I have upgrade zabbix to version 1.3.8, but the problem remains:
      the character | is supported in the trigger?
      thanks to all
      • tronite
        • Jun 2007
        • 147
        Originally posted by mardux
        hello to all.
        thanks to all
        Are you having the same problems in version 1.4?
        • mardux
          • May 2007
          • 9
          thanks for the answer.
          I have resolved the problem in this way:
          ESAFEroc.num[,,,/opt/eSafe/].last(0)<72
          bye
