zabbix triggers reversed
  • cmcintyre
    • May 2007
    I'm having a problem with triggers where, all of a sudden the alert messages a trigger sends out are reversed.
    Here's what happens:
    1. Either I get no alert or a get an alert with the appropriate message, for example "Host {HOSTNAME} is unreachable: ON"
    2. When the situation is corrected I get an alert (always) with the wrong message, for example "Host {HOSTNAME} is unreachable: ON"
    Note that it used to give me "Host {HOSTNAME} is unreachable: OFF"
    Any clues?
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    What version of ZABBIX do you use?
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • cmcintyre
      • May 2007
      I use zabbix 1.1.6 on both the server and the agent side. This is all on Linux, with the 2.6 kernel (CentOS 4.4). It seems as though there is just some bit of data that must be reversed or out of order somewhere, but I couldn't track it down. I already tried purging the alarms and alerts tables.
      If it matters we have a MySQL backend.
