map migration problem 1.1->1.4
  • richlv
    • Oct 2005
    • 3112
    it seems that sql migration script loses all maps that don't have background defined (or maybe there's some other reason, this is just a guess )
    we had one map with background and one without. after migration, second map was gone.
    migration statement refers to background images, so probably maps wihtout bg fail to transfer.
    insert into sysmaps_tmp select s.sysmapid,s.name,s.width,s.height,i.imageid,s.label_type,s.label_location from sysmaps s,images i where s.background=i.name;
  • rturmel
    • May 2007
    I just upgraded to 1.4 and noticed the same thing on my end. I could not create a new maps either. It seems succesful "new map created" but the map doesn't show up in the list. I think I used the same name for the map.
    I was succesful in creating a new map with a name I certainly had not used before. I ended re-creating my pre-1.4 maps.
    Richard
