Can not export xml - zabbix 1.4
This topic is closed.
  • Maximum
    • Sep 2006
    • 16
    Hi
    I can not "export xml", running as a "super admin" - when I click the export button nothing happens.
    The log (level 3 - default) shows nothing.
    Any Ideas ?
    Regards /Maximum
    Ubuntu 6.06 LTS Server edition
    Kernel 2.6.15-26-server #1 SMP
    Zabbix 1.4
  • abi
    • Jun 2006
    • 81
    hi,
    i can reproduce this problem. I guess its some JavaScript mess going on,
    but im not enterely sure.
    It seems like a HTTP Forward to the export file should happen but it
    doesnt.. hm..
    • Eugene
      • Feb 2006
      • 57
      Thanks for report.
      You can use this patch or SVN for 1.4.1 branch.
      • Maximum
        • Sep 2006
        • 16
        It worked
        Thank you Eugene,
        The patch worked as a charm !
        I must also say that I am very impressed by the fast response time to solve my problem.
        Best regards /Maximum
