[1.4] Use of square brackets ][ in key
  • JonB
    • Oct 2006
    • 63
    I am trying to monitor a network interface on a Windows 2003 server. The key is
    perf_counter[\Network Interface(Intel[R] PRO_100 S Desktop Adapter _2)\Bytes Received/sec]
    From zabbix_agentd.log
    11932:20070601:083424 Requested [perf_counter[\Network Interface(Intel[R] PRO_100 S Desktop Adapter _2)\Bytes Sent/sec]]
    11932:20070601:083424 Can't add counter [\Network Interface(Intel[R] [Unable to parse the counter path. Check the format and syntax of the specified path.]
    The problem is the agent is truncating the key to
    i.e the first closed square brackets is taken as the end of the key. I have tried setting an alias
    Alias = NetInerf_counter[\Network Interface(Intel[R] PRO_100 S Desktop Adapter _2)\Bytes Received/sec]
    but this is also returning as unsupported.
    Jon
  • NOB
    • Mar 2007
    • 469
    I reported a fix for 1.3.7 but it was, obviously, not integrated
    I applied a variation of it to 1.4, compiled the agent and it works fine. No
    other bugs seem to show up, e.g. if I request other keys from the same
    system.
    I won't send the binary, because i used the author edition of
    Visual C++ to create it and it does not work as a service.
    BTW: We use a Intel[R] Pro_1000 MT Dual Port Network Connection
    Regards,
    Norbert.
    • JonB
      • Oct 2006
      • 63
      Alexei,
      Any thoughts on this?
      Jon
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        It is fixed in pre 1.4.1. Please wait.
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
