1.4 Performance - Makes MySQL Very Busy?
  • agehring
    • Oct 2006
    • 49
    #16
    I was having problems with 1.4/1.4.1 (SVN) where i was basically running out of memory. While it appeared to be a memory leak, Norbert posted a patch to my thread that solved the problem.
    While none of that may seem relevant, the side effect was to make the system run at a more resonable rate.
    It may have something to do with your performance issue, no?
    Andrew
    • dlindquist
      • Jun 2007
      • 14
      #17
      Originally posted by Alexei
      There is no difference in a number of executed SQL statements per new value between 1.1.x and 1.4. If a distributed monitoring is enabled, it adds an additional insert statement, nothing more.
      OK, that's good to know...
      So why then, do I see this:
      1.1.7: One Host, the Zabbix Server, "Linux" template, all defaults == ~0.0 load average
      1.4: One Host, the Zabbix Server, "Linux" template, all defaults == ~0.4 load average
      If I use "top", I can see that generally mysqld is the most busy, and zabbix_server is vying for top spot with it...
      I still don't know why I would be seeing this...
      • dlindquist
        • Jun 2007
        • 14
        #18
        Hmm, well a couple of things seemed to help a bit:
        1. Turn off "discovery" -- it seems to generate a lot of log traffic, and turning it off reduced the mysql load some.
        2. Check your zabbix server log for items that repeatedly say 'not supported', and disable those items.
        • NOB
          • Mar 2007
          • 469
          #19
          Andrew
          no. My fix just helps if you have setup the master node with nodeid = 0
          and no slaves are defined, yet.
          In that case there is an endless loop (recursive call of a function) in zabbix_server which uses up all memory until it crashes.
          This is a very special case and has nothing to do with this performance
          problem.
          I did post my fix, to avoid that Alexei (and others) are looking for memory
          leaks where there is none. Finding memory leaks is difficult and finding
          non-existing ones even more
          Sorry, but this fix is of no help for this problem.
          I am using PostgreSQL and as fas as I have seen, the feature of
          autoincrementing values (some SQL-dialects call it "serial") is not used.
          That's why there was a report of heavy use of the DB table "ids", even
          for MySQL.
          Regards,
          Norbert.
          • Markus
            • Jan 2006
            • 39
            #20
            Hi Norbert
            for MySQL.
            regarding the issue with the 'ids' table, have you investigated this any further and found a solution? I don't really understand how to interpret your comment.
            Markus
            • bbrendon
              • Sep 2005
              • 873
              #21
              Originally posted by infinity005
              I'm not going to be scientific, but my zabbix 1.1.7 system runs between 75-300 qps and averages at about 80-85 qps
              Zabbix has 76 hosts, 1127 items active, 574 triggers active.
              It also has website databases, spamassassin, and other stuff on the same mysql server.
              When the system had 768 MB of RAM, performance was poor. It now has 1.5 GB and works fine.
              It will be interesting to see what happens with 1.4.
              I have upgraded to 1.4.1. Its not a perfect comparison because during the upgrade I made a few changes to things. I now have:
              78 hosts, 1240 items active, 653 triggers active.
              average qps is now at about 120.
              I'm wondering how I got so many new triggers... ahh! I think I imported some templates with enabled triggers. They aren't attached to hosts so I really don't have much more load. (in theory)
              Unofficial Zabbix Expert
              Blog, Corporate Site
              • YuriV
                • Feb 2006
                • 16
                #22
                Just fought with 1.4 for a few days, 99% cpu on mysql didnt matter what I did.
                Machine: P4 1.6Ghz 512Ram 20GB IDE boot running Debian Linux & 36Gb Scsi DB drive (spare parts).
                Tried messing with every option possibly on my.cnf ended up converting all tables to MYISAM from Innodb instantly solved the issue, now mysql runs between 5% - 35%
                149 hosts monitored
                495 items
                127 triggers.
                All are pinged once per minute.
                for those that care...
                # * Fine Tuning
                key_buffer = 384M
                max_allowed_packet = 16M
                thread_stack = 1024K
                thread_cache_size = 16
                max_connections = 150
                table_cache = 900
                thread_concurrency = 20
                # * Query Cache Configuration
                query_cache_limit = 1M
                query_cache_size = 32M
                Key efficiency sitting at 99.7% so far (yay), i had -1000% before... (yes negative)
                • Palmertree
                  • Sep 2005
                  • 746
                  #23
                  Found qps increasing by the second. Noticed in the mysqld.log file the following messages:
                  070711 21:02:38 [Warning] Aborted connection 33216 to db: 'zabbix' user: 'zabbix' host: 'localhost' (Got an error reading communication packets)
                  I increased the maximum size of a query packet in my.cnf and the errors and the increased qps stoped increasing.
                  # The maximum size of a query packet the server can handle as well as
                  # maximum query size server can process (Important when working with
                  # large BLOBs). enlarged dynamically, for each connection.
                  max_allowed_packet = 512M
                  • bbrendon
                    • Sep 2005
                    • 873
                    #24
                    My mysql.log is always 0 bytes. I hope that is okay.
                    • Alexei
                      Founder, CEO
                      • Sep 2004
                      • 5654
                      #25
                      Ubuntu and some other distributions automatically start checking of database integrity after server restart. It has nothing to do with ZABBIX.
                      You may run:
                      mysqladmin -uroot processlist
                      to see what MySQL is actually doing.
                      Alexei Vladishev
                      New York | Tokyo | Riga
                      My Twitter
                      • Wido
                        • Mar 2006
                        • 23
                        #26
                        I had the same problem, my server was doing over 1k QPS with Zabbix.
                        Today there was a poweroutage (how sad ) at our DC which ofcourse lead to a reboot of our Zabbix server.
                        I just checked and now the server is doing 60 QPS and is still monitoring all items?
                        I don't know where it came from, but it seems to be working now?
                        • alj
                          • Aug 2006
                          • 188
                          #27
                          Originally posted by dlindquist
                          Hi Alexei,
                          So the constant "35 queries per second" type of load that I am seeing is expected?
                          I'm running an Athlon Thunderbird 1.2 GHz with 512M RAM.
                          I was expecting to see "bursts" of activity for a very short period of time around each 30s mark as the updates were done... I wasn't expecting to see such consistent load on the DB for such a small monitoring set.
                          By simple scaling, this would seem to indicate that I'd likely see constant, 100% load trying to monitor as few as 5 or 6 hosts -- and to monitor the 30 or so machines at my work would load the fastest machine on the market at 100%... Does this sound right?
                          TIA!
                          Here's some recommendation that might help to improve performance (increased about 5 times for me):
                          1. Use InnoDB, do not use MyISAM (myisam has very bad write performance).
                          2. Give 50-70% of your physical memory to
                          innodb_buffer_pool_size=
                          parameter of my.cnf (i have 2GB there).
                          3. Turn on delayed flush on commits:
                          innodb_flush_log_at_trx_commit=0
                          4. disable transaction logging
                          (comment out log-bin) - noone usually uses it but it takes alot of IO.
                          5 (optional) increase journal size to 25% of your buffer pool size set in (2):
                          innodb_log_file_size=500M
                          Note - after you change option 5 you need to delete both journals - ib_logfile0 and ib_logfile1
                          mysql will recreate them upon startup, but back your database up before you do that.
                          6. On SMP system set number of threads equal to number of cpus.
                          innodb_thread_concurrency=2
                          (i have 2 cpu box).
                          If you set thread concurrency to 20 or something like that (as i saw somewhere in this thread) mysql performance will go down (possibly threads thrashing problem?)
                          Most of other options are less important as they mostly affect read performance when for zabbix write performance is the key.
                          Another thing to adjust is number of pollers in zabbix_server.conf.
                          default value is too small, it creates bottleneck.
                          if you set it too big - performance will be poor as well because of locking/thrashing.
                          Ofr 1.1.7 zabbix optimal value was 70 for me. For 1.4 it might be different (it will probably will be much smaller because poller processes are not being wasted for hosts that are down anymore). Do you experiments and measure how fast zabbix queue drains after you start it.
                          • alj
                            • Aug 2006
                            • 188
                            #28
                            149 hosts monitored
                            495 items
                            127 triggers.
                            # * Fine Tuning
                            key_buffer = 384M
                            table_cache = 900
                            you didnt touch innodb buffer size which is too small by default.
                            I bet that you could achieve better performance with innodb if you tuned innodb specific parameters (see my post above).
                            Heres my parameters:
                            query_cache_limit = 1048576
                            query_cache_size = 16777216
                            query_cache_type = 1
                            key_buffer = 32M
                            thread_stack = 128K
                            thread_cache_size = 80
                            # Set buffer pool size to 50-80% of your computer's memory,
                            # but make sure on Linux x86 total memory usage is < 2GB
                            innodb_buffer_pool_size=2G
                            innodb_additional_mem_pool_size=20M
                            # Set the log file size to about 25% of the buffer pool size
                            # (have top kill all binary logs if you change that, otherwise comment out next line)
                            innodb_log_buffer_size=8M
                            innodb_lock_wait_timeout=50
                            # Uncomment the next lines if you want to use them
                            P.S.
                            137 monitored hosts, 7239 monitored items, 3418 monitored triggers.
                            About key efficiency - it is measured for MyISAM only (key buffer is for myisam tables only) so your -1000% number makes total sense if you used innodb, just ignore it and use different tools that are innodb aware.
                            For MyISAM you give all memory to key_buffer_size but if you use innodb you should give that memory to innodb_buffer_pool_size.
                            If you give all memory to key_buffer_size but use innodb - no wonder you get poor performance.
                            • BHG_2008
                              • Jan 2008
                              • 23
                              #29
                              My.cnf for CentOS 5 and MySQL 5.0.24 on big box
                              CentOS 5 on Dell 1950 x86_64 with 2 quad core processors and 16GB RAM.
                              ZABBIX 1.4.4, 25 pollers, 7 pingers - 2,048 hosts, 29,422 items, 17,879 triggers
                              MySQL version 5.0.45, running on /data partition.
                              Current queries per second average is 1,854
                              my.cnf:
                              [mysqld]
                              # Locations
                              datadir=/data/mysql
                              socket=/var/lib/mysql/mysql.sock
                              # Logging
                              innodb_log_file_size            = 200M  #InnoDB journal (log) file size
                              # Troubleshooting
                              #log-slow-queries               = /data/mysql/slow.log  #Log every query exceeding log_query_time below
                              #log-queries-not-using-indexes          #Logs of every unindexed query
                              #log-bin                        = /data/binary_logs/node300       #Space and I/O HOG
                              #max_binlog_size                = 50M   #Log file size
                              #expire_logs_days               = 2     #Days before deleting binary log files
                              # Connections
                              max_user_connections            = 120
                              max_allowed_packet              = 4M
                              # Memory
                              key_buffer_size                 = 768M
                              join_buffer_size                = 64M
                              query_cache_size                = 512M
                              query_cache_limit               = 512M
                              table_cache                     = 32M
                              thread_cache_size               = 20
                              sort_buffer_size                = 64M
                              read_buffer_size                = 32M
                              read_rnd_buffer_size            = 32M
                              tmp_table_size                  = 256M
                              max_heap_table_size             = 256M
                              innodb_buffer_pool_size         = 1G
                              # Options
                              long_query_time                 = 2
                              old_passwords                   = 1
                              skip-bdb                                #Disables BDB engine
                              innodb_file_per_table           = 1     #Creates idb for every table in db folders
                              innodb_thread_concurrency       = 8     #Should match number of processors
                              [mysql.server]
                              user=mysql
                              basedir=/data
                              [mysqld_safe]
                              log-error=/var/log/mysqld.log
                              pid-file=/var/run/mysqld/mysqld.pid
                              • BHG_2008
                                • Jan 2008
                                • 23
                                #30
                                Tuned using MySQLTuner 0.9.9
