Repository of the Zabbix tool
  • jose antonio
    • Nov 2004
    My company intends to use zabbix as corporative tool, occurs that we choose postgresql because it implements the concept of data base "ACID". when we will have new versions of the Zabbix for postgresql.
  • cooper
    • Sep 2004
    • 110
    Rtfm
    Straight from the manual (http://www.zabbix.com/manual_install_server.php)
    "For PostgreSQL:
    shell> psql -U <username>
    psql> create database zabbix;
    psql> \q
    shell> cd create/postgresql
    shell> cat schema.sql|psql -U <username> zabbix
    shell> cd ../data
    shell> cat data.sql|psql -U <username> zabbix
    shell> ./configure—with-pgsql –with-net-snmp # for PostgreSQL make"
    I wonder how you know that zabbix is the right choice for you, since you obviously havent read _any_ of the documentation about the project. Come on. Do _some_ work yourself.
    cooper
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      The support of PostgreSQL will be released soon in one of 1.1 alpha versions. 1.0 already supports both: MySQL and PostgreSQL.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
