Issues with 1.4 Agent
  • rajan.s.ravi
    • Jul 2006
    • 40
    Before i was using 1.1.6 and all performance counter entries were configured in agent conf. Now i have installed the new agent (1.4) and copied the performance counter entries to this new agent conf file.
    I am not able to get any data from the performance counters and log says not supported, though this was working fine in 1.1.6. Need help urgently.
    TIA,
    Ravi
  • NOB
    • Mar 2007
    • 469
    AFAIK: the old "perf_counter" entries are no longer supported.
    You can use "alias" instead.
    But this is just from the top of my head.
    HTH,
    Norbert.
    • rajan.s.ravi
      • Jul 2006
      • 40
      Thanks for the suggestion,
      I have a perfcounter entry as below in the conf file -
      PerfCounter=Processor[Time],"\Processor(_Total)\% Processor Time",5
      please suggest on how to change it to alias.
      TIA,
      Ravi
      • tronite
        • Jun 2007
        • 147
        TIA,
        Ravi
        He's right you have to use alias instead
        • rajan.s.ravi
          • Jul 2006
          • 40
          Please guide me on how to right an alias for the following perfcounter statement -
          TIA,
          Ravi
          • rajan.s.ravi
            • Jul 2006
            • 40
            Kindly help as i am not able to use the 1.4 agent as perfmon counters are not working with this.
            TIA,
            Ravi
            • rajan.s.ravi
              • Jul 2006
              • 40
              Any thoughts on this ? i am eagerly waiting to use 1.4 agents.
              TIA,
              Ravi
              • Eugene
                • Feb 2006
                • 57
                In Your case:
                Alias=Processor[time]erf_counter[\Processor(_Total)\% Processor Time]
                • rajan.s.ravi
                  • Jul 2006
                  • 40
                  Thanks a lot, it is working fine now.
                  Regards,
                  Ravi
