SNMPv1 template
  • Markus
    • Jan 2006
    • 39
    SNMPv1 template
    Hi
    is this the right place to report bugs? The icmpInAddrMasks (itemid=18228) item of the SNMPv1 template is defined as being of type SNMPv2 (at least in SVN 4264)
    Markus
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    You're right, the type of the item is incorrect. Fixed!
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • Andreas Bollhalder
      • Apr 2007
      • 144
      Hello Alexei
      I noted that the default values for SNMP community and OID are set for items in the default DB, where I think they should be empty.
      I made an Excel worksheet (sorry, it's not OpenOffice ) and made the entries red. Can you please check this ? Maybe I'm totaly worng
      Andreas
      Zabbix statistics
      Total hosts: 380 - Total items: 12190 - Total triggers: 4530 - Required server performance: 224.2
