I'm trying to disable all items of a given template or host using table header checkbox to select all items. Header checkbox works fine, but when I click disable button, nothing happens. I must select all items, one by one, and then click on "disable selected" button to disable all items.
Another issue is: I select all items using table header checkbox, but when I click an item checkbox the table header checkbox is not unchecked. Is this the correct behavior?
but function of my squid proxy server that will not accept a URL that is that long. If I disable the transparent squid proxy then in Firefox I can update more than 75 items at a time. IE7 still fails but I suspect that may be IE more than anything else.
