Problem with action conditions
  • BSouza
    CONTEXT:
    At my environment I setup Zabbix triggers names with "key names" that represent IT teams. For example:
    [Unix-TEAM] Host unavailable
    [Backup-TEAM] Backup client unavailable
    Then I use these "key names" to alert specifics groups of people about the incident.
    I use Zabbix 1.4 upgraded from 1.1.6.
    PROBLEM:
    I have actions configured like that:
    Event source: Triggers
    Type of calculation: AND
    Conditions: Trigger description like "Backup-TEAM"
    Trigger value = "TRUE"
    Operations: Send message to Group "Backup-TEAM"
    Conditions: Trigger description like "Unix-TEAM"
    Operations: Send message to Group "Unix-TEAM"
    When, for example, trigger "[Unix-TEAM] Host unavailable" is "On", messages are sent to groups Unix-TEAM and Backup-TEAM, when they should just be sent to Unix-TEAM. The same problem occurs when I use "Host group" or "Trigger severity" to form conditions.
    Anyone has the same problem? Am I doing something wrong?
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    You're doing everything fine. Fixed and the patch is attached.
    Thanks for reporting!
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • BusteR81
      • Apr 2007
      • 150
      how to use a patch ?
      hi
      thx 4 the patch but how do i apply this patch? never try before
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Go to the directory where untarred ZABBIX sources are:
        patch -p0 <actions.patch
        Alexei Vladishev
        My Twitter
        • BusteR81
          • Apr 2007
          • 150
          thereafter?
          forgive mi but i would like to ask again should i recompile (./configure) after i apply the patch ?
          what do u mean by untarred zabbix src ? i found my actions.c here:
          /home/zabbix/zabbix-1.4/src/zabbix_server/actions.c
          should run patch from ...
          /home/zabbix/zabbix-1.4/ patch -p0 <actions.patch OR
          /home/zabbix/zabbix-1.4/src/ patch -p0 <actions.patch OR
          /home/zabbix/zabbix-1.4/src/zabbix_server/ patch -p0 <actions.patch
          Cheers
          • tronite
            • Jun 2007
            • 147
            Originally posted by BusteR81
            hi
            There's always documentation.
            • BSouza
              Thanks for the patch!
              Problem resolved!
              • NOB
                • Mar 2007
                • 469
                Cheers
                Go to directory /home/zabbix/zabbix-1.4 and start it.
                Regards,
                Norbert.
                • nebrassal
                  • Mar 2008
                  After applying the batch
                  Dear
                  I applied the batch as you said, but after this Zabbix server stops after short time with unknown reson...
                  Would you please advise me.
                  • Aly
                    ZABBIX developer
                    • May 2007
                    • 1126
                    This patch is meant for zabbix v.1.4 or 1.4.1. So just update to latest stable release.
                    Zabbix | ex GUI developer
                    • nebrassal
                      • Mar 2008
                      Dear
                      I have the version 1.4.4, and I have applied the patch.
                      So what can I do to revert to the stable version???
                      • konya.genovia
                        • Sep 2011
                        patch the action
                        Mr. NOB Alexei and members, I have run patch action.patch, FYI I was installed zabbix by apt-get install [on ubuntu 10.4] not compiled by the source..
                        when I was run the patch, I have the error that saying :
                        patching file ChangeLog
                        Hunk #1 FAILED at 1.
                        1 out of 1 hunk FAILED -- saving rejects to file ChangeLog.rej
                        patching file src/zabbix_server/actions.c
                        Hunk #1 FAILED at 566.
                        Hunk #2 FAILED at 635.
                        2 out of 2 hunks FAILED -- saving rejects to file src/zabbix_server/actions.c.rej
                        can you help me, why the reason the statement above.. thankyou
                        I'll be wait your answer
