Connection Reset By Peer: Server v1.1.6 - Client v1.4
  • CuSo4
    • Jun 2007
    Hello, I have a Zabbix server (version 1.1.6) running, and 7 Zabbix clients (version 1.1.6). When I try to add a new client (version 1.4), I get a "Connection reset by peer"-error.
    The server log says:
    ... Timeout while receiving data from [Hostname]
    ... Connection reset by peer.
    ... Host [Hostname] will be checked after 60 seconds
    I've tried both in active and passive mode.
    The client log in active mode says:
    ... zabbix_agentd started. ZABBIX 1.4.
    ... zabbix_agentd collector started
    ... zabbix_agentd active check started [serverhostname:10051]
    The client log in passive mode says:
    When I telnet from the server to the client I get:
    # telnet clienthostname 10050
    Trying x.x.x.x...
    Connected to clienthostname
    Escape character is '^]' .
    but there isn't any reaction after that. (I tried typing "version[zabbix_agentd]")
    # telnet serverhostname 10051
    Trying x.x.x.y...
    Connected to serverhostname
    Escape character is '^]'.
    QUIT
    Connection closed by foreign host.
    I have added the client & server configuration files as attachment.
    Does anyone has any suggestions about how to solve this problem?
    Thanks in advance!
  • StanZoid
    • Oct 2005
    • 47
    I have seen this same problem in my environment, and it has been caused every time by the agent machine not having a route back to the zabbix server. Add a route and fix the problem!
    Stanzoid
    • CuSo4
      • Jun 2007
      Thanks for your reply!
      However, I checked the routes, and everything seems to be fine.
      I have another client on the same vlan that works correcty.
      Furthermore, I can ping and ssh from server to client, which should also rule out a routing configuration error...
