zabbix_sender : works only with hostname
  • zabhug
    • Jun 2007
    Bonjour (just some french)
    Have you got the same pb ? (zabbix-1.4 on Linux)
    zabbix_sender -z zabbix -s hostname -k keyname -o value : OK
    zabbix_sender -z zabbix -s FDQN -k keyname -o value : failed
    zabbix_sender -z zabbix -s @IP -k keyname -o value : failed
    Little mistake in Manual v1.4-007 page 65
    ./zabbix_sender ... -h LinuxDB3 ...
    should be
    . /zabbix_sender ... -s LinuxDB3 ...
    hug (newly zabbix addicted)
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Yes, it works with host names only because it is the only (apart of hostid) unique host identifier. Commandline help and documentation is already amended to avoid any confusion.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • vstorez
      • Apr 2007
      Bonjour (an other french !)
      I discovered the same probleme...
      Just a précision : it works with the ZABBIX hostname (with which you created the corresponding host in the Zabbix frontend), and NOT the UNIX hostname.
      In most case, both are the same, and this detail is invisible....
      VS
